a problem about P_FLOW_RATE(p)
Old   September 25, 2015, 04:09
Default a problem about P_FLOW_RATE(p)
Tao Ning
potatoning is on a distinguished road
I use the DEFINE_DPM_INIT macro to define the initial flow rate of particles, and use DEFINE_DPM_BC macro and global variables to get the information of outlet particles, such as particle no. and total mass.
the question is, when I set the P_FLOW_RATE(p) larger than 1, it shows the total mass of particles is 0, but the particle no. is as usual.
I check the velocity of particles in particle tracks, and find out that the initial velocity(3m at first) of some particles is larger than 5000.
how can I solve it?
thanks a lot.
the simplification program as following:
#include "udf.h"
#include "dpm.h"
#include "global.h"
static int PN=0;
static int pn=0;
static double PMASS=0.;
static double pmass=0.;
DEFINE_DPM_BC(test1, p,t,f,f_normal,dim)
int i=0;
PN++;
pn=PN;
PMASS+=P_FLOW_RATE(p)
pmass=PMASS;
return PATH_ABORT;
DEFINE_DPM_INIT(test2,I)
Particle *p;
loop(p,I->p)
P_VEL(0)=0;
P_VEL(1)=0;
P_VEL(2)=-3;
P_DIAM(p)=0.01;
P_T(p)=300;
P_FLOW_RATE(p)=2;
DEFINE_ADJUST(time,domain)
PN=0;
PMASS=0;
potatoning is offline   Reply With Quote
Old   September 27, 2015, 17:07
`e`
`e` is on a distinguished road
The format of the particle velocity macro is P_VEL(p)[i] where p is the pointer to the tracked particle and i is the position (i = 0 for x etc). It's good practice to include trailing periods on numbers intended as real numbers (otherwise they may or may not be implicitly cast from an integer).
`e` is offline   Reply With Quote
Old   September 27, 2015, 20:33
Tao Ning
that's my mistake. in the program, it is P_VEL(p)[i].
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
