September 20, 2015, 21:21 |
Two phase flow problem
Rep Power: 11 |
I have fluidization problem with two different types of solid particles. I need to represent the drag coefficient for the interaction between the liquid phase and each of the solids using UDF instead of provided default correlations. 1-Should I provide 2 UDF to represent the drag interaction between liquid phase and each type of solids? (UDF for each case separately)? Or one common UDF is enough to represent both? 2-Should I compile or interpret the UDF. I notice that I can't interpret more than one UDF for the interaction. 3-Should I provide the particle diameter inside the UDF or it will be transferred from the main program? I am asking about this because I notice that there is a given value [diam2 3.e-4] in UDF example 1-custom drag law in the UDF manual. Thank you |
the mesh adaption problem of gas-liquid two phase flow | houwy | FLUENT | 1 | December 6, 2015 19:59 |
boundary condition problem for 2 phase flow | ahmad786 | FLUENT | 0 | September 2, 2013 03:00 |
Problem with results in 2 phase flow (airstream+rain drops) over s809 wing using DPM | yoooodarulez | Fluent Multiphase | 0 | September 1, 2013 16:42 |
error in two phase flow problem | mvee | FLUENT | 0 | March 28, 2007 05:17 |
Two phase flow problem | M.Shannag | FLUENT | 2 | December 29, 2001 12:43 |
