how to parallel a udf?
Old   January 17, 2016, 14:29
Default how to parallel a udf?
B_Kia
HyperNova is on a distinguished road
i wrote a udf code in order to correct some field quantity during every time step by using EXECUTE_AT_END macro. when i want to run code in parallel it seems the code does not have access to domain. in other words computing core can not work together. here is the code :
#include "udf.h"
DEFINE_EXECUTE_AT_END(Stabilazation)
Domain *d = Get_Domain(0);
cell_t c;
Thread *t;
real x[ND_ND];
thread_loop_c(t, d)
C_CENTROID(x, c, t);
Thread *t_water = THREAD_SUB_THREAD(t, 0);
Thread *t_air = THREAD_SUB_THREAD(t, 1);
begin_c_loop(c, t)
if (x[2] > 0.6)
C_VOF(c, t_air) = 1.0;
else
C_VOF(c, t_air) = 0.0;
end_c_loop(c, t)
any advice will be appreciated.
HyperNova is offline   Reply With Quote
Old   January 17, 2016, 15:06
sepideh
ansys13 is on a distinguished road
i have encountered the similar problem, please try this modification:
#include "udf.h"
#if !RP_HOST
cell_t c;
Thread *t;
real x[ND_ND];
thread_loop_c(t, d)
begin_c_loop(c, t)
if (x[2] > 0.6)
else
end_c_loop(c, t)
#endif
ansys13 is offline   Reply With Quote
Old   January 17, 2016, 16:43
B_Kia
Hi Sepide, thanks for your reply,
i must have examined 1000 ways to fix it. the one you mentioned was tested and same problem exists. another problem arises because i tried to share threads! so the modification you suggested does not work i am working on it and any new suggestion will be appreciated.
by the way i am a master student at khaje nasir university of technology.
Old   January 19, 2016, 13:15
RTN3000 is on a distinguished road
I'm in the same boat with trying to parallelize my code, but here's some things that I've found (which I haven't necessarily been able to implement successfully, segmentation faults everywhere) but might lead you in the right direction.
UDFs will be run on every single node, both compute and host nodes, so you'll have to state which nodes run which code by using compiler directives such as RP_NODE.
7.5.1 Compiler Directives
7.8 Parallel UDF Example
Hope this helps.
EDIT: Just noticed that ansys13 said the same thing I did. You might have to look into 7.5.9 Macros for Exchanging Data Between Compute Nodes to share the thread info. In my code, I'm trying to share the same data across nodes with use of reduction macros, but have been looking for better ways to do it.
RTN3000 is offline   Reply With Quote
"Define_Profile" UDF for parallel solver Antoine Fluent UDF and Scheme Programming 9 February 29, 2016 06:09
Problem in using UDF in parallel computing Yogini Fluent UDF and Scheme Programming 0 January 22, 2013 08:23
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 07:33
Parallel UDF Error Andrew FLUENT 2 March 30, 2007 11:11
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
