wind turbine blade simulation with flap attached to it |
March 10, 2016, 03:44 |
shahriar hossain omee
Rep Power: 11 |
hi
i am trying to simulate a vertical axis wind turbine which has 3 blades with flap attached to it.For simultaneous flapping and rotating motion i used the UDF below. Found it in the forum.Used it for a primary trial. I compiled it properly and seems to be working good but in display zone motion i see different motion for different CG location. I hooked the UDF to the flap which is rigid body.For CG location X=0, Y=0 the flap seems to only rotate about the axis. For CG location X=0,Y=0.3 (which is the radius of rotor) the body is flapping but not rotating.What should be done to get both the flapping and rotation at the same time? Any kind of help and suggestion regarding the UDF is highly appreciated. TIA Omee #include "udf.h" DEFINE_CG_MOTION(wing, dt, vel, omega, time, dtime) { real a1, a2, thxdot, thydot, thzdot, w, pi, thx, thy; pi = 3.141592654; /* define motion variables */ a1 = 30 * pi / 180; /* 30 degree flapping amplitude */ a2 = 30 * pi / 180; /* 30 degree feathering amplitude */ w = 2 * pi * 25; /* 25 Hz frequency */ /* define motion in reference axes */ thx = DT_THETA (dt)[1] * pi/180; /* flapping angle - set by orientation macro DT_THETA */ thy = DT_THETA (dt)[2] * pi/180; /* feathering angle - set by orientation macro DT_THETA */ thxdot = 0; /* flapping speed */ thydot = a2 * w * sin(w*time); /* feathering speed */ thzdot = - a1 * w * cos(w*time); /* yawing (spinning) speed */ /* define wing rotational motion in body coordinates */ omega[0] = 0; omega[1] = thydot * cos(thx) + thzdot * cos(thy) * sin(thx); omega[2] = thzdot * cos(thy) * cos(thx) - thydot * sin(thx); } |
Wind Turbine blade in 120° wedge - boundary conditions | Fcamp | OpenFOAM Running, Solving & CFD | 1 | December 2, 2019 06:47 |
How to run a wind turbine blade simulation | gerritgroot | SU2 | 6 | February 8, 2019 14:44 |
Verifying results for a wind turbine blade simulation in ANSYS CFX | Joystix | CFX | 3 | April 27, 2012 17:52 |
Wind Turbine Blade Geometry | SeanieB | Main CFD Forum | 0 | November 27, 2009 10:18 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
