compiling UDF for a dynamic mesh
Like Tree3Likes
  • 1 Post By hultman
  • 1 Post By Tameem1
  • 1 Post By yashganatra
Old   January 24, 2011, 04:19
Default compiling UDF for a dynamic mesh
Wael
Tameem1 is on a distinguished road
I'm trying to follow the dynamic mesh tutorial in Fluent 13 and Fluent 6.3.26 on windows7 64 bit. When I tried to compile the UDF and build it an error occurred:
" 'nmake' is not recognized as an internal or external command,
operable program or batch file
So I found the nmake.exe file and copy it to the Fluent\ntbin\win64 then this error vanished and the report is
Deleted old libudf\win64\2d\libudf.dll
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0.0\sr c\makefile_nt.udf "libudf\win64\2d\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\2d")()
# Generating ud_io1.h
Done.
Which I think is ok.
But when I try to load the library "libudf" an error appears
Opening library "c:\......\dynamic_mesh\dynamic_mesh\libudf".. .
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the curent platform (win64).
The system cannot find the file specified.
c:\.........\dynamic_mesh\dynamic_mesh\libudf\win6 4\2d\libudf.dll
Error Object: #f
I've tried to install MS visual studio 2010 professional and MS visual studio 2008 with all the prerequisites but no way.
Any help is appreciated, Thanks
Tameem1 is offline   Reply With Quote
Old   January 28, 2011, 09:14
Erik Hultman
hultman is on a distinguished road
I have a very similar problem,
The UDF library you are trying to load (libudf) is not compiled for 3d on the curent platform (win64). \libudf\win64\3d\libudf.dll
here you can find help: http://www.cfd-online.com/Wiki/Fluent_FAQ
I have reinstalled the compiler as they say now i will try to download the sdk package to see if that helps me out.
memeces likes this.
hultman is offline   Reply With Quote
Old   February 6, 2011, 16:36
Wael
Thank you for your reply
Finally, I found a solution. It works fine when I run the fluent from the command prompt of the visual studio, But an easy way is to set the environment for the UDF in the fluent as section 5.1.2 in the user guide. Finally it works.
Thanks
pranab likes this.
Old   July 20, 2011, 17:03
mecamor
mecamor is on a distinguished road
hello
I have a problem to you but I do not know how you managed to solve it. GUIE what you talking about? thank you
mecamor is offline   Reply With Quote
Old   June 18, 2012, 09:59
George Pichurov
jorkolino is on a distinguished road
Thanks
I followed your suggestion, and although it can now compile, it is not stable (when I re-load my file with compiled library fluent just crash-exits). Did you make it work stable with FLuent 6.3.26 on Win7-64bit? My suggestion is that compilation for v6.3.26 is not compatible with Win7-64bit, at least not fully compatible, but I need more people response. Thanks
jorkolino is offline   Reply With Quote
Old   June 19, 2012, 04:17
Blake
gy846608002 is on a distinguished road
Hello!Would you say that in detail? I have the same problem with you.Opening library "libudf"...The system cannot find the file specified.
Error Object: ()
I need your help ..Thank you !
gy846608002 is offline   Reply With Quote
Old   February 20, 2013, 12:22
Massinissa OUGHLISSI
massi.oughlissi is on a distinguished road
Hi all,
I have almost the same problem but I use LINUX.
I need your help, the error message is as follows:
Primitive error at node 0: the UDF library you are trying to load (libudf) is not compiled for parallel use in current platform (Inamd64).
No such file in directory
/work/massi/libudf/Inamd64/2d_node/libudf.so
Opening library "/work/massi/libudf"...
Error: the UDF library you are trying to load (libudf) is not compiled for parallel use in current platform (Inamd64).
Error object: #f
Thank you in advance...
massi.oughlissi is offline   Reply With Quote
Old   February 21, 2013, 09:38
Here an other error that appears, if it helps you to help me:
error: /usr/include/bits/huge_val.h: line 52: syntax error
PS: excuse my english...
Old   June 2, 2013, 07:25
Default Udf
Hadi kafil
grayeagle is on a distinguished road
thank you for your help. I have read the CFD forums and watch the pdf.
I have Visual studio C++ 2010, and SDK v7.1>
I have 4 udf (3 DEFINE_PROPERTY and 1 DEFINE_PROFILE. when I put all in one (udf) c file and compile (by using interpreted). when I use one property and one profile UDF, I don't have problem, but when I use 3 properties, there is this error:
Fluent received fatal signal (Access_Violation)
1-....
2-....
3-....
grayeagle is offline   Reply With Quote
Old   July 6, 2013, 02:42
Yash Ganatra
yashganatra is on a distinguished road
Access violation error indicates the fault inside a UDF. It is trying to access a quantity which is not there, as far as I know
Yash
massi.oughlissi likes this.
yashganatra is offline   Reply With Quote
Old   August 22, 2013, 03:57
tran trung
tranvantrung551987 is on a distinguished road
Thanks
hello
i get the same error. Can you help me
thank you
tranvantrung551987 is offline   Reply With Quote
Old   July 8, 2015, 22:39
Nisar Fatima
nisarfatimaaeroengr@gmail is on a distinguished road
To overcome the problems related to any compiling errors, follow the ensuing steps:
1) install Microsoft visual studio 2010 express.
2) install Microsoft windows sdk v7.0
3) run setenv.exe file from ur system location C:\Program Files\ANSYS Inc\v145\fluent\ntbin\win64\setenv.exe.--(to set required environment variables)
4) Restart ur system and launch fluent using CMD shell [(start menu<<All programs<< Microsoft windows SDK v7<< CMD shell). Note :in CMD shell ,type fluent].
IMPORTANT: pay heed to the working directory while launching fluent as it should contain the source file that needs to be compiled.
Gudluck
nisarfatimaaeroengr@gmail is offline   Reply With Quote
Old   August 5, 2015, 05:47
Vinh Ha Tien
Havinh is on a distinguished road
dear
I have got this problem too.
I have tried all the tutorial I can found in the internet but nothing happen
However, I have installed VS 10 Ultimate version and this problem was gone
So i think the problem it you are using free version of VS (i have tried all free version form VS8 to 2013 but just using VS 10 ultimate only)
I have solve all my computer and my partner by this way.
So try it now
Havinh is offline   Reply With Quote
Old   December 28, 2015, 05:50
Default Ya folwed Havinh's Guidelines and i got solution
  #14
Chotai Nikhil
nikhilchotai@gmil.com is on a distinguished road
Havinh's Solution is Correct As Followed it and i m able to solve all Tutorial
nikhilchotai@gmil.com is offline   Reply With Quote
Old   May 24, 2016, 11:19
Apiano Morais
Apiano is on a distinguished road
Gudluck
Thank you very very much!
Apiano is offline   Reply With Quote
dynamic mesh, udf compilation
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Dynamic mesh UDF problem Peter FLUENT 2 November 12, 2007 02:10
writing a dynamic mesh udf ALPER ALBAYRAQ FLUENT 0 October 24, 2005 08:41
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 09:29
UDF problem for dynamic mesh??? lyf FLUENT 1 April 19, 2004 06:43
