UDF-electric field
Like Tree3Likes
Old   April 11, 2005, 18:08
Default UDF-electric field
Srinivas
hi,
i want to model electric field on particles. In my case because of field particles attain constant velocity, which will be equal to electrophoretic mobility*electric field. Can any one tell me how to do it.
thanks,
Srinivas
Old   April 12, 2005, 03:18
Default Re: UDF-electric field
Harish
There is an electromagnetic module available as an addon to fluent . check if it available with your fluent version. Otherwise learn how to include udf functions and you got to add the effect of the field through the udf.
-H
Old   October 10, 2011, 01:51
Default please help me
akbar
akbar is on a distinguished road
can any body help me for simulate electrical field in fluent ?
please contact me with akbariakbar10@yahoo.com
thanks
akbar is offline   Reply With Quote
Old   October 10, 2011, 05:13
Default electric field
rose
rubis is on a distinguished road
hi ,
can you activate a electric field in fluent if you use MHD model.
yours
rubis is offline   Reply With Quote
Old   October 28, 2012, 11:22
Default Fluent version
payamfadaei
Payam89 is on a distinguished road
Send a message via Skype™ to Payam89
Hi Dear
Which version of FLUENT does have MHD addon modules ?
thanks
Payam89 is offline   Reply With Quote
Old   October 29, 2012, 22:24
vaseem akram shaik
vsmkrm298 is on a distinguished road
Hi
I dont know about the fluent modules, but i solved the similar problem.
U can get the electric field by solving the poissons equation for applied or induced potential. This u need to do by defining a udf. So, now u can take the derivative of potential to get electric field in both directions.
ambrish4u, Payam89 and liuzexiang like this.
vsmkrm298 is offline   Reply With Quote
Old   October 30, 2012, 01:21
payamfadaei
thanks you very much
Do you still have your UDF to help me during my job?
many thanks
Old   October 30, 2012, 01:48
vaseem akram shaik
ya, i have that udf so that i can help you
Old   October 31, 2012, 08:37
liuzexiang
liuzexiang is on a distinguished road
Originally Posted by vsmkrm298 View Post
Hi
which edition! can u supply some message?
liuzexiang is offline   Reply With Quote
Old   November 1, 2012, 05:22
Exclamation @ vsmkrm298
rocky
ambrish4u is on a distinguished road
for the applying mhd, which type of geometry should b prepared.....
means, is we hv to make some special geometrical part for that ?????
please help me out....thnks
ambrish4u is offline   Reply With Quote
Old   November 1, 2012, 05:25
vaseem akram shaik
i cant understand what u are asking
Old   November 1, 2012, 06:24
Post vsmkrm298
  #12
rocky
actually i have to apply electromagnetic field rectangular duct, but at a particular region....so for that i have make any different volume at that region
for example i have attached the pic....
Old   December 2, 2012, 02:47
payamfadaei
In which part exactly do you want to apply electromagnetic field?
Old   December 4, 2012, 01:31
Default @ Payam89
  #14
rocky
as i hv shown in the figure, i.e. in a duct of 50 cm of length i have to apply electromagnetic field with stirring effect within 10 cm in between.
thanks....
Old   December 4, 2012, 02:00
payamfadaei
After you active MHD panel.you should first select 2 face and then put on voltage to to each face.then you run and it will show you electric field...but if you have magnetic field it doesn't need any iteration.
Old   December 11, 2012, 05:39
rocky
@ Payam89
thanks 4 ur reply....
since i hv to apply mhd in some area....so do i hv 2 make some geometry of that area...
because when i m applying mhd, result comes for complete area....or there is any other way for that....
Old   December 11, 2012, 12:31
Default Electric Field
  #17
payamfadaei
how can it understand in which area you are going to apply electric field....you should tell him!
you need to apply 2 faces
Old   December 12, 2012, 01:16
rocky
@Payam89
yes u r right but it always ask only for the zone(i.e. fluid or solid).... not for any plane or wall...
thanks...
Old   November 24, 2016, 21:48
Peter Aestas
aestas is on a distinguished road
I had worked on MHD before and i change the software to OpenFOAM...
aestas is offline   Reply With Quote
Old   May 22, 2017, 05:49
Default udf on electric field
  #20
upc
Xiaohui Li
upc is on a distinguished road
Hi, I am working on electric field coalescence with fluent. Could you please send me you udf on electric field as well? Thank you very much!
upc is offline   Reply With Quote
Effects of droplets to each other in an electrostatic field alighaffari Fluent UDF and Scheme Programming 4 August 31, 2017 02:22
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Charge transport UDF ak6g08 Fluent UDF and Scheme Programming 1 June 27, 2011 04:21
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
