udf for gradient
Old   July 4, 2012, 16:26
Smile udf for gradient
honglin wang
Honglin is on a distinguished road
#include "udf.h"
FILE *fid;
real flow;
real x;
real p;
real g;
real xc[ND_ND];
DEFINE_EXECUTE_AT_END(EXECUTE_AT_END)
Domain *d;
Thread *t ;
face_t f;
cell_t c;
d=Get_Domain(1);
t= Lookup_Thread(d, 6);
fid=fopen("flux.dat","w");
begin_f_loop(f, t)
c= F_C0(f, t);
flow = F_FLUX(f,t);
/* fprintf(fid,"MASS FLOW RATE:%g\n",flow);*/
end_f_loop(f,t)
begin_c_loop(c,t)
C_CENTROID(xc,c,t);
x=xc[0];
p = C_P(c,t);
g = C_P_RG(c,t)[0];
fprintf(fid,"x-coordinate:%g\t",x);
fprintf(fid,"Static PRESSURE:%g\t",p);
fprintf(fid,"PRESSURE GRADIENT:%g\n",g);
end_c_loop(c,t)
fclose(fid);
There have error at the end of one time steps. g = C_P_RG(c,t)[0]; it may be have some problem. If I remove it ,the result is right. Please help me!!!!!!!!!! Thank you !
Honglin is offline   Reply With Quote
Old   July 6, 2012, 08:46
akm
akm is on a distinguished road
did you enable the gradient macros using text commands?
solve/set/expert
Keep temporary solver memory from being freed? Yes
Also to use C_P_RG() you have to use the second order discretization scheme for pressure.
Alternatively, you can use C_P_G(c,t)[0] which need not have a second order discretization scheme.
Hope that helps.
akm is offline   Reply With Quote
Old   July 6, 2012, 10:08
honglin wang
Thanks for your reply. I am so glad for response.
of course.
my cas use desity solve.
I had checked the result of radient use showgrad.c, but tht result only have C_P_RG() ,not C_P_G() . Do you have further advice?
Thanks again.
Best regards
lin
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
