May 28, 2013, 10:01 |
Problems in air flow udf - divergence
Rep Power: 13 |
Hi, I'm having problems in my UDF, I'm new in fluent and I'm trying to make a on-off air machine. But when I put to calculate, fluent shows a message: divergence in AMG solver.Here is my C file, if anyone could help me, please send a message, because I'm lost here...
PS: I'm catching average temperature and moisture by calculating the total area and the area*temperature/moisture in face, than divisioning them. #include "udf.h" #include "math.h" static real umid_avgFd = 0.005; static real temp_avgFd = 293.15; static real temp_avgF = 293.15; static real deltaTemp = 0; static real umid_avgF = 0.05; static real ma = 0.25; static real Q = -5; static real a = -2940.94; //Parâmetros do controlador // AC static int AC = 1; static real wsonoff = 0; static real tsonoff = 0; static real we; DEFINE_EXECUTE_AT_END(controller) { real Tsat; real setpoint = 293.15; // [k] real massFlowRate = 0.485376; // [kg s^-1] real specHeat = 1005; // [J kg^-1 K^-1] real B; real C; real Qm; real dT = 1; real mar = 0.25; // fluxo de ar em kg/s real SPS = setpoint + (dT/2); real SPI = setpoint - (dT/2); real dhSens = 0; Domain *d; Thread *t; face_t f; real A[ND_ND]; real area; real temp = 0; real temp_avg = 0; real area_tot = 0; real calorOut = 0; real To = 0; real Ti = 0; real Te = 0; real Ts = 0; real Tss = 0; real Tsl = 0; real umid = 0; real umid_avg = 0; real b = 0; real c = 0; real wsl = 0; real ws = 0; real wss = 0; // Relacionando variáveis às localizações. d = Get_Domain(1); t = Lookup_Thread(d,10); // temperature in outlet. begin_f_loop(f, t) { // F_T is for temperature in the faces. // F_AREA save the area value in vector A. F_AREA(A,f,t); area = NV_MAG(A); area_tot += area; temp += F_T(f,t)*area; } end_f_loop(f, f_thread) // Calculating the temperature. temp_avg = temp / area_tot; temp_avgF = temp_avg; To = temp_avgF/ma; temp = 0; temp_avg = 0; area_tot = 0; // moisture in outlet. begin_f_loop(f, t) { // F_YI pega dados de umidade nas faces. // F_AREA armazena o valor da área no vetor A. F_AREA(A,f,t); area = NV_MAG(A); area_tot += area; umid += F_YI(f,t,1)*area; } end_f_loop(f, f_thread) // Cálculo da temperatura média na superfície. umid_avg = umid / area_tot; umid_avgF = umid_avg; we = umid_avgF; temp = 0; temp_avg = 0; area_tot = 0; // Relacionando variáveis às localizações. t = Lookup_Thread(d,9); // Dados de temperatura no inlet. begin_f_loop(f, t) { // F_T pega dados de temperatura nas faces. // F_AREA armazena o valor da área no vetor A. F_AREA(A,f,t); area = NV_MAG(A); area_tot += area; temp += F_T(f,t)*area; } end_f_loop(f, f_thread) // Cálculo da temperatura média na superfície. temp_avg = temp / area_tot; temp_avgF = temp_avg; Ti = temp_avgFd/ma; ///////////////////////////////////// //Declarando variáveis wss = we; Tsat = 15.66*log(1000*we)-21.695; Te = To; dhSens = 1.005*(Te-Tsat)+we*1.82*(Te-Tsat); b = 1243 + (1.82*(15.66*log(1000*we)-21.70)+2500.8+5203.2*we+2.92+2500.9); Qm = -Q/ma; c = Qm+(-1.005*Te)+(-1.82*we*Te)+(1.82*we*Tsat)+(-2500.8*we)+(-1.233)+(5.16*we)+(-2500.9*we); Tss = (Te-(Qm/1.005+1.82*we)); //condição para o valor de wsl if((-b*pow(2*a,-1))+(pow(b*b-4*a*c,0.5))*pow(2*a,-1)>we) { wsl = we; }else { wsl = -b*pow(2*a,-1)+(pow(b*b-4*a*c,0.5))*pow(2*a,-1); } //achando valor de Tsl Tsl = 15.66*log(1000*wsl)-21.695; //condição para o valor de Ts if(Qm>dhSens) { Ts = Tsl; }else { Ts = Tss; } //condição para o valor de ws if(Qm>dhSens) { ws = wsl; }else { ws = wss; } //condição para controladot onoff if(Ti>(To-(dT/2))) {if(To>SPS) { AC = 1; } else { AC = 0; } }else {if(To<SPI) { AC = 0; } else { AC = 1; } } // condição para temperatura if(AC==1) { tsonoff = Ts; }else { tsonoff = To; } //condição para umidade if(AC == 1) { wsonoff = ws; }else { wsonoff = we; } } //Define a temperatura do inlet DEFINE_PROFILE(temp_inlet,t,i) { face_t f; begin_f_loop(f,t) { F_PROFILE(f,t,i) = tsonoff; } end_f_loop(f,t) } //Define a umidade do inlet DEFINE_PROFILE(umid_inlet,t,i) { face_t f; begin_f_loop(f,t) { F_PROFILE(f,t,i) = wsonoff; } end_f_loop(f,t) } |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Multiphase Flow - Convergence Problems | bastian26 | FLUENT | 0 | September 19, 2011 07:26 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
