Velocity profile UDF
Old   May 8, 2012, 18:29
Default Velocity profile UDF
egge24 is on a distinguished road
I'm trying to create a tranverse velocity profile UDF to use it as velocity inlet boundary condition to simulate flow in a water tank. The UDF is as follows:
DEFINE_PROFILE(Velocity_Profile_Z, thread, index)
real x[ND_ND]; /* this will hold the position vector */
real z;
face_t f;
begin_f_loop(f, thread) /* loops over all faces in the thread passed
in the DEFINE macro argument */
F_CENTROID(x,f,thread);
z = x[1];
if (z < 0)
z = z*(-1);
else
F_PROFILE(f, thread, index) = 1*pow((z/(12.8)),0.142857);
end_f_loop(f, thread)
When I run the simulation, once it converges I plot a XY Plot, see attached figure . In my case the Z-axis represents the abscissa and the velocity magnitude the ordinate. The plot shows that even do the function represents the desire velocity profile, there is almost none velocity magnitude variation!!!
Does anyone have an idea of why is that happening??
Thanks in advance.
[/URL]
egge24 is offline   Reply With Quote
Old   May 9, 2012, 04:11
Daniel Tanner
Daniel Tanner is on a distinguished road
You have set z = x[1]. This is the y direction on your mesh, is that correct? The x vector is given by: (x[0], x[1], x[2]) which is equivalent to (x,y,z).
Worth checking this.
Daniel Tanner is offline   Reply With Quote
Old   May 10, 2012, 13:03
Thanks Daniel!!
That was the problem!!!!!
UDF problems - velocity profile Oli Fluent UDF and Scheme Programming 6 October 24, 2016 10:38
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
How to specify the Velocity profile (eqn) by UDF Anant FLUENT 1 February 27, 2008 14:54
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 06:47
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
