problem with udf loading(nmake.exe)
Old   March 22, 2009, 06:10
Default problem with udf loading(nmake.exe)
gholamghar is on a distinguished road
hello
I have visual studio 2008 and Fluent 6.328 installed on my computer,
every time i want to load LIBUDF library from
Define:>User-defined:>Functions:>Compiled it gives me this error:
> #f
Opening library "libudf"...
Error: open_udf_library: The system cannot find the path specified.
Error Object: ()
i searched in the forum and someones suggested that it is a problem with nmake.exe.
anybody knows how i can fix this problem with nmake.exe?
thanks
gholamghar is offline   Reply With Quote
Old   March 22, 2009, 10:56
RenardP is on a distinguished road
The problem is that your Fluent doesn't know where to find your Visual C++ compiler, I hope you have the Pro edition (I don't thinck it will work with Express).
Try to start Fluent using the Visual Studio Command Prompt window, write these in the command prompt:
fluent 2ddp
or
fluent 3ddp
RenardP is offline   Reply With Quote
Old   March 23, 2009, 04:28
paka is on a distinguished road
keep in mind your already compiled (in Visual Studio Command Prompt window) routine the best should be in libudf/ folder within you case folder. It means if your case.cas file is in folder C:\test\ then libudf/ path should be like this: C:\test\libudf\ .
As soon as your function is compiled you do not need to call compiler from within Fluent. Your compiled function is a stand alone program, which to run just need Fluent call to it the way you do it.
paka is offline   Reply With Quote
Old   March 23, 2009, 14:41
thank you PAKA and RenardP,with your advices i solved my problem.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 09:29
udf problem shan FLUENT 6 March 17, 2004 03:01
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
