host_to_node data transfer
Old   May 18, 2009, 12:32
Default host_to_node data transfer
Ellen
EllenW is on a distinguished road
I need to transfer a 2-d array from the host to nodes, but I didn't find any such examples in the udf manual. suppose my array is A[20][4], how should I write for this: host_to_node_real(A, 20,4)?
could anyone please help me on this? Thank you so much.
ellen
EllenW is offline   Reply With Quote
Old   May 19, 2009, 04:33
Max
coglione is on a distinguished road
Hello Ellen,
i guess you have to split your multi-dimensional array into e.g. 4 1-d arrays of length 20 and use the common host-to-node macros. Each node will have to resemble the full array again.
This is really nasty, thus if you find a more elegant way let me know.
cheers
coglione is offline   Reply With Quote
Old   May 19, 2009, 12:46
gemini is on a distinguished road
I think serial data transfer method using standard macros located inside a loop structure can be used. If you dont have a solution yet you can try this.
regards
gemini is offline   Reply With Quote
Old   May 19, 2009, 16:37
Ellen
thank you for your reply, coglione. There seems to be no direct way for this transfer operation... I'll convert my 2d array as you suggested then.
thanks,
ellen
Old   May 19, 2009, 16:41
Ellen
I just saw your reply, gemini, thanks. but I'm not quite sure how to carry out your suggested method, could you elaborate more or give an example?
thank you.
Old   May 30, 2009, 11:34
thank you.
Hi ElllenW,
I'm sorry, I don't have a ready example for you, however, you can start with the section titled as "7.5.8 Message Passing Macros" in UDF manual (/help/html/udf/node214.htm) in which low-level message passing macros are described and there is an example about data transfer between nodes and between node0 and host. I think that section will be helpful. Btw, if I reach any example about your case, I'll write here.
Good luck
Data Transfer - Polyflow to Fluent to Abaqus Bob Carson FLUENT 0 March 27, 2007 09:31
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Star to Nastran/Patran Data Transfer A.S. Siemens 0 February 14, 2005 08:08
Transfer data in MPI hall Main CFD Forum 0 May 3, 2004 18:57
Data transfer H. P. LIU Main CFD Forum 5 May 19, 2003 10:47
