April 23, 2009, 22:23 |
[UDF] Segmentation violation
Vivek
Rep Power: 17 |
Hi folks,
I am working on simulating flow through a HPLC column. The solid matrix geometry is constructed by importing CT scans of the solid phase. I have been able to succesfully simulate steady state flows in my model. Now I am working on simulating a pulse on the steady state flow. This involves unsteady state simulation using species transport. I have written a UDF to simulate a pulse at my inlet boundary at t = t0. The other boundary condition is to have species mass fraction gradient at the outlet = 0. This is where I face a few problems. My geometry consists of about 1 million unstructured tet cells. I separate the cells immediately adjacent to the outlet boundary using Adapt/Boundary into a new fluid zone. I now want to set the conc gradient in this zone = 0. Here is the UDF that I use for both the inlet pulse as well as for outlet zero conc gradient: #include "udf.h" DEFINE_PROFILE(pulse,t,i) { face_t f; real time = CURRENT_TIME; if (time == 1) begin_f_loop(f,t) F_PROFILE(f,t,i) = 0.1; end_f_loop(f,t) else begin_f_loop(f,t) F_PROFILE(f,t,i) = 0.0; end_f_loop(c,t) } DEFINE_PROFILE(concgrad,thread,species) { cell_t c; Domain *d; Thread *t; int ID = 17; d = Get_Domain(1); t = Lookup_Thread(d,ID); if (!Data_Valid_P()) return; begin_c_loop(c,t) C_YI_G(c,t,0)[0] = 0.0; C_YI_G(c,t,0)[1] = 0.0; C_YI_G(c,t,0)[2] = 0.0; end_c_loop(c,t) } I hook udf concgrad to my outlet boundary under the Species tab. The problem is when I load the case file (with UDFs already hooked), and then load the steady state data file, I receive a Segmentation Violation. I also believe that to make C_YI_G available in a pressure based solver (which is what I use), I need to type: (rpsetvar species/save-gradients? #t) in the text-interface. However, this does not make any difference. Could someone kindly guide me how to go about setting my outlet boundary condition? Thanks and Regards, Vivek Vasudevan |
How to remove the error:FLUENT received a fatal signal (SEGMENTATION VIOLATION). | Conan | FLUENT | 9 | December 20, 2019 12:31 |
Segmentation Violation | Corentin | FLUENT | 1 | February 13, 2011 01:07 |
segmentation violation | wasan | FLUENT | 0 | December 23, 2008 11:37 |
Segmentation Violation | Axel | FLUENT | 2 | May 26, 2006 12:16 |
SEGMENTATION VIOLATION | kROZ | FLUENT | 1 | May 4, 2006 09:12 |
