Received a fatal Signal ( Segmentation fault ) |
June 28, 2017, 12:32 |
Hi everyone !
I hope you are fine. I am using UDF in VOF model in ANSYS FLUENT, although, my VOF model without UDF is running fine. The UDF is written by my friend used it successfully. He has graduated last year. The UDF was working well on his server. He was using Fluent 6.3 on Linux system. When I am using same case, date and UDF on my laptop the case is not running, although UDF compilation is very fine. I also check it on Linux system too. During or after initialization, Error occurred segmentation fault error. It is very strange that same case and UDF is not working on his office now. Main error occurred when I am hooking ADJUST and EXECUTE-AT-END UDFs. May be there is some problem of writing/calling style is different in Windows and Linux system with 32bit and 64bit. ( this is just my opinion). I hope you can understand the situation and have a try to fix the problem. I would be highly thankful if you guide me that where is the problem.. Thanks in Advance, Regards, M. F. ALi |
June 28, 2017, 17:32 |
sebastian bergman
Rep Power: 9 |
June 29, 2017, 00:32 |
#3 | |
Regards M. F. Ali |
fluentError: received a fatal signal (Segmentation fault). | thomaszhangjing | Fluent UDF and Scheme Programming | 11 | January 13, 2021 09:37 |
Fluent udf Error: received a fatal signal (Segmentation fault) Error Object: #f | dikmeha | Fluent UDF and Scheme Programming | 20 | April 13, 2018 04:06 |
Error: received a fatal signal (Segmentation fault). | MayTheFlowBeWithYou | FLUENT | 12 | June 30, 2017 03:09 |
Received a fatal signal (Segmentation fault) with UDF | lisa_china | Fluent UDF and Scheme Programming | 2 | June 30, 2017 03:07 |
Wave Tank Numerical Beach Error: received a fatal signal (Segmentation fault) | Shyam Kaushik | Fluent Multiphase | 0 | November 15, 2016 13:59 |
