May 7, 2009, 07:19 |
Plotting coordinates of face centroids
Rep Power: 17 |
Hi @all,
I'm trying to display the coordinates of the face centroids of a wall zone via UDM in contur plot panel. I'm using the following UDF to determine the coordinates and to put them into UDMs: #include "udf.h" DEFINE_ON_DEMAND(face_centrs) { Domain *d; Thread *t; face_t f; real x[ND_ND]; int domain_id, blade_id; domain_id = 1; blade_id = 17; /* get the domain pointer to the flow_domain */ d = Get_Domain(domain_id); /* get the thread pointer to the bladethread */ t = Lookup_Thread(d,blade_id); begin_f_loop(f,t) { F_CENTROID(x,f,t); F_UDMI(f,t,0)=x[0]; F_UDMI(f,t,1)=x[1]; F_UDMI(f,t,2)=x[2]; Message("y-coord: %f \n", F_UDMI(f,t,1)); } end_f_loop(f,t); } As you can see, I print the y-coordinate to the screen which works perfectly. But when I want to display the UDMs in the contour plot panel, all the values are zero. Can anyone tell where my mistake is? I'd really appreciate any help. cheers |
May 7, 2009, 08:21 |
Daniel Tanner
Rep Power: 18 |
This is a bit painful. Basically the contour plot in fluent only displays cell-centered data, i.e., it interpolates the cell-centre value to the face and then displays it. If you are using F_UDMI you are not storing the values at the cell centre - hence, it will be zero!
You could use C_UDMI instead but I am not sure if the value you save needs to be adjusted to account for the interpolation. See this link for details on using the C_UDMI for displaying face variables: http://www.cfd-online.com/Forums/flu...cent-wall.html http://www.cfd-online.com/Forums/flu...-gradient.html |
May 7, 2009, 08:47 |
Rep Power: 17 |
Hey Daniel,
that was exactly the hint I needed, thanks a lot!!!!! cheers |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
