UDF is working in Laptop, but not working in Serial Cluster
Old   December 20, 2013, 21:42
Default UDF is working in Laptop, but not working in Serial Cluster
Tanjina Afrin
Tanjina is on a distinguished road
Hello everyone,
I am facing a weird problem. This is the UDF for assign hydrostatic pressure on one face.
#include "udf.h"
DEFINE_PROFILE(pressure_profile,t,i)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y=x[1];
F_PROFILE(f,t,i)=(0.4898-y)*998.2*9.81;
end_f_loop(f,t)
It is working properly when I run it on my Laptop. But it's not working on Cluster, even I select serial processor. it gives me the following error.
cpp -I"/opt/ansys_inc/v145/fluent/fluent14.5.0/src" -I"/opt/ansys_inc/v145/fluent/fluent14.5.0/cortex/src" -I"/opt/ansys_inc/v145/fluent/fluent14.5.0/client/src" -I"/opt/ansys_inc/v145/fluent/fluent14.5.0/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "/home/tafrin/side_inlet_wide_12_8.75_files/dp0/FFF/Fluent/hello.c"
Error: /home/tafrin/side_inlet_wide_12_8.75_files/dp0/FFF/Fluent/hello.c: line 2: syntax error.
For parallel processor, it also gives gives the same error. I can understand that for parallel, it needs some modification, but for serial why it is not working on cluster, I don't understand. I didn't use C language before, so facing difficulties to debug the problem.
Could anyone please help me in this regard?
Thanks in advance.
Regards,
Tanjina
Last edited by Tanjina; December 21, 2013 at 00:43. Reason: adding appropriate word
Tanjina is offline   Reply With Quote
cluster, parallel computation, serial, udf
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
UDF Working At The Same Time Carlos V. FLUENT 0 March 21, 2006 11:30
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 10:19
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
