help, parallel udf problem
Old   June 26, 2009, 15:54
Default help, parallel udf problem
Ellen
EllenW is on a distinguished road
Hi everyone,
I guess I still don't understand well how things work in parallel mode, so I got all kinds of problems when trying to run udfs which worked fine in the serial mode. Now I narrow down my problems into this one:
my udf has two parts: part I is reading a table of property data and store it into an array, which is done in a DEFINE_EXECUTE_ON_LOADING macro; the second part is to define a property using the data stored in the array from part I, and this is done using a DEFINE_PROPERTY macro.
when trying to run this udf in parallel mode, I used the directive #!RP_NODE on part I, since the file-read operations (fopen, fread...) normally are handled by the host or serial process.
Then I used the directive #!RP_HOST on part II, since the host process doesn't contain any grid information.
my problems are:
1. This parallelized file can be sucessfully complied, but after loading it, I found the part I of my code was not executed (I checked using a Message statement in part I)
2. If I take out part II, trying to test Part I only, then it cannot pass the complilation. I was prompted something like "improper end of file";
3. if I take out part II and take out the directive (#!RP_NODE) around part I, then I have this compliation error:
udf_names.c(7) : error C2059: syntax error : '}'
udf_names.c(8) : warning C4034: sizeof returns 0
I'm really stuck here, any suggestions from you would be helpful, especially examples (or tips) on how to handle DEFINE_EXECUTE_ON_LOADING type of macro.
Thank you in advance,
ellen
EllenW is offline   Reply With Quote
Old   August 1, 2010, 05:30
Default udf_names.c(7) : error C2059: syntax error : '}'
ahmad
almostafa67 is on a distinguished road
hello dear Ellen...
did u find your answer hot to correct this error message ( udf_names.c(7) : error C2059: syntax error : '}') that fluent have given you.know i'm facing with this problem and i want u as a Experienced person help me out...
looking forward to ur help
almostafa67 is offline   Reply With Quote
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
Parallel UDF problem Lindsay FLUENT 4 June 20, 2016 09:37
UDF parallel Lucy Fluent UDF and Scheme Programming 3 May 28, 2013 13:14
udf on parallel fluent stud Main CFD Forum 0 December 12, 2008 07:45
parallel mode - small problem? co2 FLUENT 2 June 1, 2004 23:47
