Trap and reflect udf
Old   July 10, 2009, 10:51
Unhappy Trap and reflect udf
sadegh motallebi
motallebi is on a distinguished road
HI
I am gonna write a udf about the DPM.
I am gonna write a udf that can trap or reflect. On the other hand I can trap if shear stress lower than critical shear stress. otherwise it can reflect.
I used of swich command and another command But It does not work for me.
I wanna use of REMOVE_ PARTICLE FALSE that delet some of the particle .
It can use to solve this problem.
At the udf manual 6.2.3 write a udf about the DPM OUTPUT.
At the this program uses of REMOVE_ PARTICLE FALSE .
#include "udf.h"
/* UDF that samples discrete phase size and velocity distributions*/
/* within the domain. */
#define REMOVE_PARTICLES FALSE
DEFINE_DPM_OUTPUT(discrete_phase_sample,header,fp, p,t,plane)
#if RP_2D
real flow_time = solver_par.flow_time;
real y;
if(header)
par_fprintf_head(fp," #Time[s] R [m] X-velocity[m/s]
W-velocity[m/s] R-velocity[m/s] Drop Diameter[m]
Number of Drops Temperature [K] Initial Diam [m]
Injection Time [s] \n");
if(NULLP(p))
return;
if (rp_axi && (sg_swirl || rp_ke))
y = MAX(sqrt(SQR(p->state.pos[1]) + SQR(p->state.pos[2])),DPM_SMALL);
else
y = p->state.pos[1];
#if PARALLEL
par_fprintf(fp,"%d %d %e %f %f %f %f %e %e %f %e %f \n",
p->injection->try_id,p->part_id, P_TIME(p),y,p->state.V[0],
p->state.V[1],p->state.V[2],P_DIAM(p),p->number_in_parcel,
P_T(p), P_INIT_DIAM(p),p->time_of_birth);
#else
par_fprintf(fp,"%e %f %f %f %f %e %e %f %e %f \n",
P_TIME(p), y,p->state.V[0],p->state.V[1],p->state.V[2],P_DIAM(p),
p->number_in_parcel, P_T(p), P_INIT_DIAM(p), p->time_of_birth);
#endif /* PARALLEL */
#else
real r, x, y;
if(header)
par_fprintf_head(fp," #Time[s] R [m] x-velocity[m/s]
y-velocity[m/s] z-velocity[m/s] Drop Diameter[m]
if(NULLP(p))
return;
x = p->state.pos[0];
r = sqrt(SQR(x) + SQR(y));
#if PARALLEL
p->injection->try_id, p->part_id, P_TIME(p), r,p->state.V[0],
#else
P_TIME(p), r,p->state.V[0],p->state.V[1],p->state.V[2],
P_DIAM(p),p->number_in_parcel,P_T(p), P_INIT_DIAM(p),
p->time_of_birth);
#endif
#if REMOVE_PARCELS
p->stream_index=-1;
#endif
But it does not describe obout the this command.
Can you help me about the description for this command?
ALL THE BEST.
THANK YOU
MOTALLEBI
motallebi is offline   Reply With Quote
Old   October 8, 2013, 07:05
Smile کمک
Reza Yosri
rezayo is on a distinguished road
سلام برادر
مشکل منم اینجوریه
میخوام با سرعت بحرانی بسنجه
اگه udf رو داشته باشی ممنون میشم به منم بدی
rezayo is offline   Reply With Quote
please help me. i have question about the UDF at the DPM motallebi FLUENT 0 July 6, 2009 11:27
I have a big problem at the UDF. Please help me motallebi FLUENT 1 July 3, 2009 11:10
DPM BC Trap or Reflect RIK FLUENT 8 October 28, 2008 06:09
DPM Boundary Conditions, UDF Juan FLUENT 1 November 11, 2005 14:37
Help with UDF for BC needed. Albert FLUENT 1 January 7, 2004 13:32
