Identifying cell in parallel UDF
Old   July 24, 2013, 11:27
Default Identifying cell in parallel UDF
upeksa is on a distinguished road
I have an DEFINE_ON_DEMAND serial UDF which stores in a memory the cell index, like this:
begin_c_loop(c,t0)
if (/*certain condition*/)
C_UDMI(c0,t0,0)=c;
end_c_loop(c,t0)
The next step of my code is reopen the same case in PARALLEL Fluent and execute another UDF code which will store in another memory the pressure of the cell whose index has been previously stored, like the following:
begin_c_loop(c,t0)
C_UDMI(c0,t0,1)=C_P((int)(C_UDMI(c0,t0,0)),t0);
end_c_loop
The point is that my UDF works properly in serial process, but it doesn't work at all in parallel process.
In conclusion, I need to create an UDF which will be able to retrieve an index of some cell which had been previously stored in a memory and work IN PARALLEL as well.
Maybe I should do a loop of partitions, but I don't have actually any idea.
Could someone give me some advices or hints in order to parallelize UDFs?
Thanks in advance.
Best regards.
upeksa is offline   Reply With Quote
fluent, parallel, parallel processing, parallelize udf, udf
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 07:33
UDF for linear temperature profile on horizontal parallel surfaces. Chirag2302 Fluent UDF and Scheme Programming 0 February 4, 2012 00:44
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 13:53
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 00:36
