A Problem of Fluent Interpreted UDF: parse error
Like Tree6Likes
Old   February 19, 2010, 15:42
Unhappy A Problem of Fluent Interpreted UDF: parse error
PengYun
knight is on a distinguished road
Hello guys!
I am a newly learner of Fluent, I got some problems with my UDF file when I compiled it in Fluent.
I don't want to bother you, while I really searched everywhere but didn't find a good solution. I hope someone could help me
my fluent path:
C:\Fluent.Inc\fluent\ntbin\ntx86\fluent.exe -r6.2.16
Model exported by GAMBIT path:
E:\dissertation\fluent模型\2010-2-5\A11\a11.msh
Udf file(it is a peroidical velocity inlet)
E:\dissertation\fluent模型\2010-2-5\A11\velocity2.c
run FLUENT, READ CASE--A11.MSH,Done!
Then,DEFINE--UDF---INTERPRETED UDF---velocity2.c
It is reported that:
cpp -IC:\Fluent.Inc\fluent\fluent6.2.16/src
-IC:\Fluent.Inc\fluent\fluent6.2.16/cortex/src
-IC:\Fluent.Inc\fluent\fluent6.2.16/client/src
-IC:\Fluent.Inc\fluent\fluent6.2.16/multiport/src -I.
-DUDFCONFIG_H="<udfconfig.h>"
E:\dissertation\fluen 模型\2010-2-5\A11\velocity2.c
Error: E:\dissertation\fluent模型\2010-2-5\A11\velocity2.c: line 1: parse
error.
It's said that there is one PARSE ERROR in line 1,then I opened this velocity.c in VC++
#include "udf.h"
#include "stdio.h"
#include "math.h"
#include "stdlib.h"
DEFINE_PROFILE(inlet_velocity1, thread, i)
Domain *domain;
Thread *f_thread ;
face_t f;
float time;
// float inlet_d=0.397e-3;
// float ave_v=1.0;
// x0=-0.528e-3;
// y0=0.00000;
// z0=0.00000;
time=CURRENT_TIME;
begin_f_loop(f, thread)
F_PROFILE(f, thread, i) = abs(0.003*sin(2*6.283*time));
end_f_loop(f, thread)
When compiling, VC said:
e:\dissertation\fluent模型\2010-2-5\a11\velocity2.c(1) : fatal error C1083:
Cannot open include file: 'udf.h': No such file or directory
error when running cl.exe
I remember there is no need to compile udf in VC. Just compiling it in fluent is Ok, because fluent will find the udf.h in its directory. But it seems my Fluent wouldn't cooperate. It turned the error to my velocity.c
Expecting help!
Sincerely thanks
Knight
knight is offline   Reply With Quote
Old   April 19, 2010, 20:17
sourav singh
souravsingh1987 is on a distinguished road
I am facing in the same problem.. can someone please help..
souravsingh1987 is offline   Reply With Quote
Old   May 24, 2010, 03:04
Pacheo
pacheo is on a distinguished road
Originally Posted by knight View Post
Hello guys!
my fluent path:
error.
#include "udf.h"
#include "stdio.h"
#include "math.h"
#include "stdlib.h"
Domain *domain;
Thread *f_thread ;
face_t f;
float time;
// float ave_v=1.0;
// x0=-0.528e-3;
// y0=0.00000;
// z0=0.00000;
time=CURRENT_TIME;
Expecting help!
Sincerely thanks
Knight
u'd better not include chinese characters in your work folder.
try again.
pacheo is offline   Reply With Quote
Old   February 21, 2011, 10:42
Default math.h stdio.h stdlib.h udf.h in UDFs of FLUENT
Engr Adeniyi
Galileo is on a distinguished road
This thread is old, but I faced similar problem and found this thinking the way out would have been discussed.
The way round would be to use this header only
#include "udf.h"
and leave out these headers:
#include "stdio.h"
#include "math.h"
#include "stdlib.h"
udf.h defines most of what is needed.
Hope this helps someone else.
AvaShahrokhi, Pacific and thedal like this.
Galileo is offline   Reply With Quote
Old   April 7, 2011, 03:45
cdf_user is on a distinguished road
make sure you include the full path to the file when you select the file through 'browse'. same goes for udf_library in build during compiling
cdf_user is offline   Reply With Quote
Old   March 13, 2012, 04:23
Nicola
sirnick is on a distinguished road
Thank you very much Galileo, you save me!!
sirnick is offline   Reply With Quote
Old   April 18, 2013, 12:46
nnvoro is on a distinguished road
I need to use Bessel functions and complex numbers in my udf to set womersley profile in the inlet, when I leave only #include "udf.h" in the header Fluent can't interpret my udf. How can I cope with this problem?
nnvoro is offline   Reply With Quote
Old   April 27, 2013, 06:00
Engr Adeniyi
I am not quite clear with what you want to do, but for you to get help, you need to post more details. For example, you need to say what the error is; are you interpreting or compiling; how complex numbers will work in a BC. Unless you are using one of the parts of a complex number, it will be difficult to code z=a+ib.. You need to be able to express the problem in simple equation or the form the equation will take.
Old   April 28, 2013, 14:10
Engr, I really appreciate that you answered me. The problem was that I was trying to write my boundary conditions in a compact form, for that I used expressions which contained imaginary numbers and Bessel functions. I was taking real part of this expression which is than was used for boundary conditions. Thus I needed imaginary numbers in order to avoid bulky expressions in my udf.
Now, my problem is solved, I did the thing I was trying to avoid, I wrote my udf without using imaginary numbers and Bessel functions.
Galileo likes this.
Old   May 1, 2013, 05:29
Wu Zhuo
mumu678 is on a distinguished road
感觉使用udf.h就可以满足需求
mumu678 is offline   Reply With Quote
Old   May 6, 2013, 06:17
Default salam
  #11
tehran
armanrazy is on a distinguished road
because u used a space before include
Pacific likes this.
armanrazy is offline   Reply With Quote
Old   December 8, 2013, 09:00
Default error while building udf
  #12
siddharth mittal
siddharth12 is on a distinguished road
I am getting error while compiling udf in fluent 13.0.0
error is
module machine type 'x64' conflicts with target machine type 'X86'
please help
please....
siddharth12 is offline   Reply With Quote
Old   March 5, 2016, 01:26
Default Parse error
  #13
kalaivani
kalaivani is on a distinguished road
Sir,
Sir,
I tried to work out an example in LNA in ANSYS tool . I got the result.But if i replace it by a HEMT model i get the parse error as Cant interpret this device.Please provide me a solution so that it would be helpful for me to arrive at good solutions.
kalaivani is offline   Reply With Quote
Old   January 16, 2018, 01:37
Default "error:E:fluent/volume.c;line 28 parse error." The udf are as follows:
  #14
wan zhihua
zhihuawan is on a distinguished road
Hi,nnvoro,I meet the same problem,can you help me?this is my problems.
when I interpret the udf to the fluent,it gives errors "error:E:fluent/volume.c;line 28 parse error." The udf are as follows:
udfexample.c
UDF for specifying volume profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_volume, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y, h;
face_t f;
h = -0.0009; /* inlet height in m */
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
y = x[1];
if (y<h)
F_PROFILE(f, thread, position) =1;
else {
F_PROFILE(f, thread, position) =0;
zhihuawan is offline   Reply With Quote
Old   January 16, 2018, 04:47
obscureed is on a distinguished road
Dear Zhihuawan,
You start the face loop with "begin_f_loop(f,thread) {", so you need to end it with "} end_f_loop(f,thread)" -- note the closing "}", which is currently missing.
I would highly recommend that everyone trying to write UDFs (or other code) uses a text editor that indents automatically, and that shows matching pairs of opening brackets/braces/parentheses/etc. If you don't have time to learn vim or emacs, try Notepad++ and look for auto-indent.
Also, this thread is about interpreted UDFs. I would highly recommend using compiled UDFs unless your sys-admins make it completely impossible. Interpreted UDFs are very restricted (and probably slow, though I have never tested this).
Best regards,
Ed
pakk likes this.
obscureed is offline   Reply With Quote
Old   January 17, 2018, 20:31
Default [QUOTE=obscureed;678284]Dear Zhihuawan, You start the face loop with "begin_f_loop(f
  #16
wan zhihua
Originally Posted by obscureed View Post
Dear Zhihuawan,
Best regards,
Ed
Thank you very much .I solve my problem by your idea. but I have some questions:
(1)I want to send you the udf files, but I do not know how.
(2)I also want to compile it ,but it failed ,should I change the udf to be a compiled udf.How can do it ?
(3)Can you tell me what should learn if I want to master the udf prgramming.
Thank you very much.
Old   January 17, 2018, 20:56
Default This is the pictures about my udf and error tips.
  #17
wan zhihua
Dear Zhihuawan,
Best regards,
Ed
Old   January 18, 2018, 02:16
pakk will become famous soon enough
Attachment 60866
Attachment 60867
Please show the error that you get when you try to compile the udf. Not the error that you get when you try to load the udf.
You should see a warning about line 12 or 13. The code that you used is slightly different from the code that you posted on this forum.
pakk is offline   Reply With Quote
Old   January 18, 2018, 06:24
Default [QUOTE=pakk;678527]Please show the error that you get when you try to compile the udf
  #19
wan zhihua
I do not know how to comiled the udf ,can you tell me how to do it?Yes ,I plus a "}" before the "end_f_loop(f,thread)",therefore ,it can works.
Old   January 18, 2018, 07:47
You were able to find the "load" button. On the same screen, there is the "build" button. You should click the "build" button before you click the "load" button.
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
