Gradient of UDS
Like Tree1Likes
  • 1 Post By gemini
Old   June 13, 2009, 13:56
Unhappy Gradient of UDS
gemini is on a distinguished road
Hi everyone,
I want to calculate the gradient of a UDS by using Green Gauss theorem using cell based approximation for face values of UDS. Below you can see the corresponding c code. However i created a simple test case which contains a square domain (in which UDS solved using dirichlet type BCs) and test whether my gradient function and C_UDSI_G(c, t, uds_no) gives the same values. The result is that my function gives totally different and unrealistic gradient values while C_UDSI_G gives correct values,
So anybody can help me to correct the code below:
I used both uniform and nonuniform structured grids.
thanks so much
real evaluate_gradient(cell_t c, Thread *t, int i_uds, real *x_vec, real *y_vec, real *z_vec)
    int n;
    face_t f;
    Thread *tf;
    Thread *t0, *t1;
    cell_t c0, c1;
    real A[ND_ND];
    real grad_phi[ND_ND];
    ND_SET(grad_phi[0],grad_phi[1],grad_phi[2],0.0,0.0,0.0);
    c_face_loop(c, t, n)
        f  = C_FACE(c,t,n);
        tf = C_FACE_THREAD(c,t,n);
        c0 = F_C0(f,tf);
        t0 = THREAD_T0(tf);
        if (!BOUNDARY_FACE_THREAD_P(tf))
            c1=F_C1(f,tf);
            t1=THREAD_T1(tf);
        else
            c1=-1;
            t1=NULL;
        F_AREA(A,f,tf);
            NV_V_VS(grad_phi,=,grad_phi,+,A,*,(0.5*(C_UDSI(c0,t0,i_uds)+C_UDSI(c1,t1,i_uds))));
        else
            NV_V_VS(grad_phi,=,grad_phi,+,A,*,C_UDSI(c0,t0,i_uds));
    *x_vec = grad_phi[0]/C_VOLUME(c,t);
    *y_vec = grad_phi[1]/C_VOLUME(c,t);
    *z_vec = grad_phi[2]/C_VOLUME(c,t);
    return 0.0;
DaveD! likes this.
gemini is offline   Reply With Quote
Old   October 22, 2013, 21:16
Default search help
liu hongbo
biker is on a distinguished road
hi, do you have solved the problem about how to get second order graident of UDS,i have the same problem now, and have no way to do it .could you give me some help ?,waiting for your reply,thanks
biker is offline   Reply With Quote
Old   December 24, 2013, 00:24
xingangzheng
ustbdynamic is on a distinguished road
Dear liu:
Do you have solve this problem?
I meet the same problem as yours.
thank you
ustbdynamic is offline   Reply With Quote
reconstruction gradient of a UDS gemini Fluent UDF and Scheme Programming 0 June 7, 2009 16:03
Gradient of UDS ling FLUENT 0 September 22, 2006 05:50
Gradient UDS tom FLUENT 1 April 28, 2006 03:46
UDS gradient Arek FLUENT 0 July 10, 2000 07:52
Gradient of a UDS Ilkay FLUENT 0 March 8, 2000 13:42
