UDF error - parabolic velocity profile - 3D turbine
Like Tree1Likes
  • 1 Post By skris2009
Old   May 11, 2010, 01:45
Default UDF error - parabolic velocity profile - 3D turbine
Zaqie
Zaqie is on a distinguished road
Hi
I was trying to write a UDF for a parabolic velocity profile for a turbine problem. The parabolic shape is only in the vertical direction(y direction), i.e velocity steadily increases upwards the domain(see the attached figure). Maximum velocity -1.73 m/sec. Domain diameter - 30m
The UDF is as followsreference fluent manual)
UDF for parabolic velocity profile at inlet boundary
#include"udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position) /* inlet x velocity = name of the x velocity */
real x[ND_ND];
/* this will hold the position vector */
real y,z;
face_t f;
/* f = all the cell faces on the boundary*/
begin_f_loop(f,thread)
/* thread = given boundary zone, defined automatically when the UDF is hooked to inlet boundary, the macro begin_f_loop is applied to all the cell faces*/
F_CENTROID(x, f, thread);
/* the coordinates of the face centroid accessed by F_CENTROID */
y= x[1];
F_PROFILE(f, thread, position) = 1.73-((15-y)*(15-y)*1.73/(30*30));
/* return velocity is assigned through F_PROFILE */
end_f_loop(f, thread)
But on compiling my UDF I get the error
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Any clue what the error is?
Regards
Zaqie
Zaqie is offline   Reply With Quote
Old   May 11, 2010, 11:30
Default problem solved
Zaqie
The source file was named parabolic profile.c . I removed the gap between the words in source files - parabolicprofile.c and it works!
Old   May 24, 2010, 23:08
Default 3d Parabolic Profile Error
Sowmya K
skris2009 is on a distinguished road
Hi
I have the following UDF written for fully developed flow as a boundary condition for a pipe inlet. The inlet face is on the Y-Z plane and the velocity is normal to the face in the X direction. But if I check the initialization, the profile doesnt look parabolic at all. I have just modified the profile given the Fluent guide.
#include "udf.h"
#include "math.h"
DEFINE_PROFILE(inlet_x_velocity, thread, index)
real x[ND_ND]; /* this will hold the position vector */
real y;
real z;
real a;
face_t f;
begin_f_loop(f, thread) /*loops over all faces in the thread passed in the DEFINE macro argument*/
F_CENTROID(x,f,thread);
y =x[1];
z =x[1];
a = pow((pow(y,2)+pow(z,2)),0.5);
F_PROFILE(f, thread, index) = 2*0.00000491976*(1- (a*a/(0.10214*0.10214)));
Any ideas will be appreciated. Thanks
soheil_r7 likes this.
skris2009 is offline   Reply With Quote
Old   May 24, 2010, 23:30
Sowmya K
Nevermind, I got it...
stupid mistake....it should be z=x[2]
Thanks anyways
Old   September 6, 2012, 06:14
n7310889
n7310889 is on a distinguished road
Hi, could any of you can tell me whats wrong with this macro? Its for 3d to provide input heat-flux profile around a semi circular cylinder of 33mm radius and 1.5m long.The heat profile varies along the verticle y direction and translates the same along the horizontal z axis.
#include "udf.h"
DEFINE_PROFILE(heat_profile,thread,index)
real x[ND_ND];
real x,y,z,r,angle;
face_t f;
x =x[0];
y =x[1];
z =x[2];
r =sqrt(pow(x,2)+pow(y,2));
angle =acos(-y/r);
if ((z>=0.0) && (z<=1.4))
if ((angle>=0.0) && (angle<=60.0))
F_PROFILE(f,thread,index) =6500.0;
if ((angle>50.0) && (angle<=180.0))
F_PROFILE(f,thread,index) =0.0;
else
end_f_loop(f,thread)
n7310889 is offline   Reply With Quote
Old   September 20, 2012, 07:05
rayolau
rayolau is on a distinguished road
Hi, I am working in similar 3D case. At the moment, my macro is this:
____________________________________
#include "udf.h"
#define S 0.0016
real x [ND,ND];
real y;
real z;
face_t,f;
y=x[1]
z=x[2]
if (y>=S)
F_PROFILE(f,thread,index)=0.55*double log (double (y/0.0016))
But on compiling my UDF I get the error. Why? What's wrong?
Thanks!
rayolau is offline   Reply With Quote
Old   September 23, 2012, 01:48
hzsme
hzsme is on a distinguished road
Try to declare the (face_t f at first and then other variables....like this:
face_t f;
real x [ND,ND];
real y;
real z;
Also there is an extra character between (face_t) and (f)....i mean the comma.....omit it and then compile your UDF.
Bests.
hzsme is offline   Reply With Quote
Old   September 23, 2012, 03:23
n7310889
face_t f;
real x [ND,ND];
real y;
real z;
Bests.
Thanks a lot.
However, I've written a udf for heat flux, and it is running well. Now I'm trying to add radiation in that macro at a fashion like that: F_PROFILE(x,t,i) = heat_flux_function - some_constant*(pow(F_T(f,t),4)-pow(Temp_glass,4));
Whenever I try to interprate this macro, fluent shows me parse error, just at this line. One thing I'm wondering is, I'm assigning input heat to a certain face and again use the temperature of the same face to negate radiation exchange from the resultant heat flux! Input heat will be utilized first to raise the face temperature, then radiation exchange will be function of this temperature, is my understanding. I don't understand actually how should I assign radiation exchange in my model. Could you please help me to get rid of this riddle? I'll be thankful really.
Regards
Old   May 11, 2014, 08:34
fouad
Fouad Far is on a distinguished road
Hello every body.
I would like to ask a question about UDF. I want to write a velocity profile with use of UDF an I don't know How I can write this periodic profile:
thank you.
Fouad Far is offline   Reply With Quote
Old   June 25, 2016, 19:08
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Originally Posted by Fouad Far View Post
Hello every body.
Attachment 30761
thank you.
This code will help you otherwise see the tutorial at
https://confluence.cornell.edu/displ...rcating+Artery
UDF CODE
/* vinlet_udf.c
/* UDFs for specifying time dependant velocity profile boundary condition
//Written by Chiyu Jiang
//Cornell University
#include "udf.h"//file that contains definitions for define functions and fluent operations
#define PI 3.141592654
DEFINE_PROFILE(inlet_velocity,th,i)
face_t f;
begin_f_loop(f,th)
double t = (CURRENT_TIME*2-floor(CURRENT_TIME*2))/2; //t is the local time within each period
if(t <= 0.218)
F_PROFILE(f,th,i) = 0.5*sin(4*PI*(t+0.0160236));
else
F_PROFILE(f,th,i) = 0.1;
end_f_loop(f,th);
Shamoon Jamshed is offline   Reply With Quote
3d turbine, compile, macro, parabolic velocity, udf
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
UDF problems - velocity profile Oli Fluent UDF and Scheme Programming 6 October 24, 2016 10:38
How to make a UDF to have a velocity profile in a square channel Gigis Fluent UDF and Scheme Programming 8 January 13, 2013 22:20
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
