May 12, 2010, 17:11 |
CX_Find_Cell_With_Point: problem
Francesco Capuano
Rep Power: 16 |
Hi everyone,
I've got a problem with the function CX_Find_Cell_With_Point, which I've found right in this forum (it is not mentioned in the UDF manual): you give it the coordinates of the point, it gives you back the cell index in which the point is. The example given by the user Gearboy was: #include "udf.h" DEFINE_ON_DEMAND(find_cell) { cell_t c; Thread *t; CX_Cell_Id cx_cell; real NV_VEC(pt); real c_centroid[ND_ND]; NV_D(pt, =, 0.5, 0.3, 0.2); //coordinate of your specified location,it must be in the domain coordinate range CX_Start_ND_Point_Search(); cx_cell=*CX_Find_Cell_With_Point(pt); CX_End_ND_Point_Search(); c=RP_CELL(&cx_cell); //the right cell number t = RP_THREAD(&cx_cell); // the thread C_CENTROID(c_centroid,c,t); Message0("coordinate of the specified point: x=%g,y=%g,z=%g\n",pt[0],pt[1],pt[2]); Message0("coordinate of the cell found: x=%g,y=%g,z=%g\n",c_centroid[0],c_centroid[1],c_centroid[2]); } The problem is: if I use this function for a single point, or for a loop of points in a flat-plate mesh, it works perfectly; if I use this function inside a loop of points for any other case, even very simple (like an airfoil), Fluent simply goes off after a while (during the elaboration), despite all the points in the loop are in the domain coordinate range and, apparently, there are no other problems with the case and the rest of the function. It seems like a memory limit is reached, or something like that. I'm quite new to Fluent and UDFs world, so I really don't know what to do, I really appreciate any suggestion. Thanks in advance! |
May 13, 2010, 14:36 |
Francesco Capuano
Rep Power: 16 |
I precise that after some seconds of elaboration Fluent gives ACCESS VIOLATION error... help me please!
May 15, 2010, 08:28 |
Rep Power: 16 |
try to replace real NV_VEC(pt);
with float NV_VEC(pt); I had a problem with this UDF and that change solved it... Pedro Last edited by psc3; May 15, 2010 at 13:39. |
May 16, 2010, 15:51 |
Francesco Capuano
Rep Power: 16 |
Thank you Pedro for your suggestion, that's a good idea, but it doesn't work for my case.
Anyway, I've fixed the bug: I realized that the problem for the function was to analyze the points belonging to the boundary face (probably it is unable to judge whether they belong to the computational domain or not), so excluding that points from the loop the UDF works fine. |
May 17, 2010, 07:30 |
Dragos
Rep Power: 20 |
Are you sure it works ok?
This instruction: Code:
cx_cell=*CX_Find_Cell_With_Point(pt); Code:
cx_cell = CX_Find_Cell_With_Point(pt); |
May 17, 2010, 09:55 |
Francesco Capuano
Rep Power: 16 |
Thanks for helping, dmoroian, but the function CX_Find_Cell_With_Point(pt) requires the asterisk. As I said, the problem does not regard the syntax, but the point you ask the function to analyze. It seems not to work fine for the boundary points...
August 26, 2013, 15:08 |
Rep Power: 12 |
This line Code:
cx_cell = CX_Find_Cell_With_Point(pt); Code:
cx_cell=*CX_Find_Cell_With_Point(pt); error C2440: '=' : cannot convert from 'int' to 'CX_Cell_Id'Does anybody know how to avoid it? |
August 27, 2013, 01:17 |
You do not provide the full warning/error message, do you? It could be misleading. There should be some warning messages tell 'implicit declaration of function CX_Find_Cell_With_Point'. Please include the right header file,
#include "cxiface.h" The interface for this function changed in version 14 so I do not discuss the header file in this version because the above code does not work any way. |
August 27, 2013, 03:37 |
#9 |
Rep Power: 12 |
Thank you blackmask,
I'm using the latest version, that's 14.5.7. There is no more cxiface.h and a grep search revealed there is no more CX_Find_Cell_With_Point either. Has anybody an idea how the corresponding commands are called in 14.x.x? |
August 27, 2013, 05:11 |
#10 |
Dragos
Rep Power: 20 |
Yes it is in
fluent/fluent14.5.7/cortex/src/cxndsearch.h |
August 28, 2013, 04:21 |
#11 |
Rep Power: 12 |
Thanks a lot for that!
But the syntax seems to be a bit more complex than before. Code:
FLUENT_EXPORT ND_Search *CX_Start_ND_Point_Search(ND_Search *, cxboolean do_domain, int t_id); FLUENT_EXPORT CX_Cell_Id *CX_Find_Cell_With_Point(ND_Search *, double v[3], double time); FLUENT_EXPORT ND_Search *CX_End_ND_Point_Search(ND_Search *); Code:
CX_Start_ND_Point_Search(); cx_cell=*CX_Find_Cell_With_Point(pt); CX_End_ND_Point_Search() |
April 5, 2014, 21:35 |
#12 | |
Jason
Did you figure out this problem??? I am suffering the exactly same problem as yours. Could you guys give any suggestion? Appreciate! |
June 24, 2014, 13:14 |
#13 | |
Garvit Goel
Rep Power: 12 |
I cant under stand what t_id and v[3] and time are. |
January 18, 2016, 03:57 |
#14 |
Maria
Rep Power: 12 |
January 18, 2016, 04:01 |
#15 |
Maria
Rep Power: 12 |
July 19, 2016, 03:09 |
Solution for v. 17.1
#16 |
Anders Simonsen
Rep Power: 12 |
Hi
I tool a look at it and figured out how to do it. Ansys has posted a note on their website (required user access): Macro CX_Find_Cell_With_Point form hasAfter messing around with it I found a way to locate the cell: Code:
#include <udf.h> #include "cxndsearch.h" static ND_Search *domain_table = NULL; DEFINE_ON_DEMAND(locate_cell) { cell_t c; Thread *t; CX_Cell_Id *cx_cell; real P[3]; real P_Cell[3]; domain_table = CX_Start_ND_Point_Search(domain_table,TRUE,-1); for (int i = 0; i < 100; i++) { P[0] = 0.0; P[1] = 0.0; P[2] = (real)i / 100.0 * 5.0; cx_cell = CX_Find_Cell_With_Point(domain_table,P,0.0); if (cx_cell) { c = RP_CELL(cx_cell); t = RP_THREAD(cx_cell); C_CENTROID(P_Cell,c,t); Message("Found cell at [%g,%g,%g] with centroid [%g,%g,%g].\n",P[0],P[1],P[2],P_Cell[0],P_Cell[1],P_Cell[2]); } else { Message("Could not find cell at [%g,%g,%g]!\n",P[0],P[1],P[2]); } } domain_table = CX_End_ND_Point_Search(domain_table); } |
October 19, 2016, 01:15 |
#17 |
Rep Power: 12 |
so good job!!
December 25, 2016, 21:24 |
Problems running in PARALLEL
#18 | |
You
Rep Power: 9 |
But I've got a problem in parallel running. When I use this UDF in parallel processing, it returns me the error notice like this: 0 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054 MPI Application rank 0 exited before MPI_Finalize() with status -1 0: mpt_read: error: read failed trying to read 4 bytes: No such file or directory The Parallel FLUENT process could not be started. My benchmark is a 2D rotor problem, a rectangular water channel with a cross blender in it. I used the "Mesh motion" for the rotating zone surrounding the blender and the "interface" boundary condition. What I want to do is MONITORING THE PRESSURE ON A DYNAMIC POINT. This point is initially located in the rotating zone and it will rotate with the zone synchronously. Now I have tried many methods, such as the different MPI methods and I have check the RAM and I have made sure the firewall is closed ......by the way, my workstation can run other udfs using the parallel processing, this UDF is the only one that cannot be used in parallel running. At last I found that the problem result form the macro "RP_CELL" and "RP_THREAD", when I made these two codes as notes , it can run well in parallel. So please help me .Please.Please. My e_mail is :youjf@whu.edu.cn My udf is here: ************************************************** ****** #include "udf.h" #include "surf.h" #include"cxndsearch.h" static ND_Search *domain_table=NULL; real R=0.05; static float xTheory=0.20535;/*The initial x coordiate of the dynamic monitoring point*/ static float yTheory=0.13535;/*The initial y coordiate */ static float theta=0.785398;/*The initial phase angle */ static float p01=0.0;/*The initial pressure */ static float tim=0.0; float c_centroid[2]; DEFINE_EXECUTE_AT_END(execute) { #if !RP_NODE FILE *fp_p01; #endif double pt[2]; cell_t c; Thread *t; CX_Cell_Id *cx_cell; #if !RP_NODE tim=RP_Get_Real("flow-time"); theta=theta+0.001*10;/*The angular velocity is 10 rad/s and the timestep is 0.001s */ xTheory=0.17+R*cos(theta); yTheory=0.1+R*sin(theta); pt[0]=xTheory; pt[1]=yTheory; domain_table = CX_Start_ND_Point_Search(domain_table,TRUE,-1); cx_cell=CX_Find_Cell_With_Point(domain_table,pt,0. 0); c=RP_CELL(cx_cell);/*The error should RESULT FROM this macro */ t=RP_THREAD(cx_cell);/*The error should RESULT FROM this macro */ C_CENTROID(c_centroid,c,t); p01=C_P(c,t); domain_table = CX_End_ND_Point_Search(domain_table); #endif #if !RP_NODE fp_p01=fopen("p01.txt","a+"); fprintf(fp_p01,"%15.4f\t%d\t%d\t%d\t%15.6f\t%15.6f \t%15.6f\t%15.6f\t%15.6f\t%15.6f\t\n",tim,cx_cell, c,t,theta,xTheory,yTheory,c_centroid[0],c_centroid[1],p01); fclose(fp_p01); #endif } |
December 26, 2016, 04:42 |
#19 |
Anders Simonsen
Rep Power: 12 |
Hi youjfwhu
I haven't tried anything in Fluent, but I'm pretty sure the problem is that you're using (#if !RP_NODE) instead of (#if !RP_HOST). Remember that when you're running Fluent in parallel, the cells are located on the computer nodes. The host is only there to do some communication stuff etc. So when you're trying to locate cells using CX_Find_Cell_With_Point in a section of your code, which is only running on the host (!RP_NODE), you'll get an error. I've used my own piece of code on a parallel process as well, where it works just fine. But in my code, the CX_Find_Cell_With_Point is located within a (!RP_HOST)-section. |
December 26, 2016, 09:47 |
Problem still exists
#20 | |
You
Rep Power: 9 |
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument The Parallel FLUENT process could not be started. Actually I think your suggestion is very important and useful. The first timestep is finished and the whole udf is processed(since the last 3 sentences of the udf is about printing some messages on a *.txt file and the results shows that it is correct). I paste my new udf here, could you please help me again? Thank you so much. ************************************************** #include "udf.h" #include"cxndsearch.h" static ND_Search *domain_table; real R=0.05; static float xTheory=0.20535; static float yTheory=0.13535; static float theta=0.785398; static float p01=0.0; static float tim=0.0; static float c_centroid[2]; static cell_t c; static Thread *t; static CX_Cell_Id *cx_cell; static double pt[2]; DEFINE_EXECUTE_AT_END(execute) { #if !RP_HOST FILE *fp_p01; #endif #if !RP_HOST tim=RP_Get_Real("flow-time"); #endif #if !RP_HOST theta=theta+0.001*10; xTheory=0.17+R*cos(theta); yTheory=0.1+R*sin(theta); pt[0]=xTheory; pt[1]=yTheory; #endif #if !RP_HOST domain_table = CX_Start_ND_Point_Search(domain_table,TRUE,-1); cx_cell=CX_Find_Cell_With_Point(domain_table,pt,0. 0); c=RP_CELL(cx_cell); t=RP_THREAD(cx_cell); C_CENTROID(c_centroid,c,t); p01=C_P(c,t); domain_table = CX_End_ND_Point_Search(domain_table); #endif #if !RP_HOST fp_p01=fopen("p01.txt","a+"); fprintf(fp_p01,"%15.4f\t%15.6f\t%15.6f\t%15.6f\t%1 5.6f\t%15.6f\t%15.6f\t\n",tim,theta,xTheory,yTheor y,c_centroid[0],c_centroid[1],p01); fclose(fp_p01); #endif } |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
