June 8, 2010, 18:21 |
dynamique mesh
alliche redha
Rep Power: 15 |
I have a problem with the dynamic mesh in fluent displays an error message as I Click <build>
Here the main window the messege is 'nmake' is not recognized as internal or external command, operable program or batch file. help me s v p Last edited by cheredha; June 8, 2010 at 19:13. |
June 8, 2010, 18:47 |
alliche redha
Rep Power: 15 |
Is anyone there
June 10, 2010, 02:32 |
Rep Power: 18 |
Not sure what might be the reason, but the way it look I would say your compiler is not hooked up to your Fluent distribution. Try to interpret your function instead of using precompiled one. At least in Ansys Fluent 12 interpret function works well, I used to have some trouble with Fluent 6.3.
Hope that helps. |
June 10, 2010, 05:00 |
alliche redha
Rep Power: 15 |
thank you paka, this course has solved the problem, the program is not installed nmake, now I have another problem, when making the file source, put it with the file. cas, where I was a (where I instaled the fluent!).
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
dynamique mesh | cheredha | FLUENT | 0 | June 8, 2010 12:35 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
