mass flow rate inlet udf
Old   June 3, 2010, 09:03
Red face mass flow rate inlet udf
ali
alikami is on a distinguished road
i have a case in which mass flow rate increases for 0.5 sec.
anybody , can give a udf for the problem
thanks
regards
ali
alikami is offline   Reply With Quote
Old   June 3, 2010, 09:17
Ibn Hasan
Aminullah is on a distinguished road
U've just like my prob. maybe U can figure it out through read the tutorial UDF (note: U've the equation, if U familiar to C language (NOT C++) U an do it easily)
Good Luck...
Aminullah is offline   Reply With Quote
Old   June 3, 2010, 09:58
Red face
ali
yes i solved. thanks
one more problem...
how to give particle mass flow rate using udf???
any idea....
regards
ali
Old   June 4, 2010, 13:47
Default Compiler ?
Elango
elango86 is on a distinguished road
which compiler are you using.i have dev c++ is it advisable to use this to write the udfs or should i be using just c
elango86 is offline   Reply With Quote
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 18:55
The reporting of mass flow rate summer FLUENT 1 July 12, 2007 09:35
journal file command for writing mass flow rate James FLUENT 0 July 26, 2006 10:51
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
