udf for changing rotational velocity
Old   September 24, 2010, 03:16
Default udf for changing rotational velocity
peterchen is on a distinguished road
I'd like to create an UDF to change the wall rotation during an unsteady simulation after a certain amount of time.
It seems that I can't put the UDF in the wall settings if I'm selecting a rotating wall.
Is there an easy solution or do I have to select "components" instead of "rotational" and change the UDF?
Thanks for your help,
peter
peterchen is offline   Reply With Quote
Old   September 24, 2010, 04:03
Max
coglione is on a distinguished road
There is a macro called THREAD_VAR(thread).wall.omega
that can be used to set the rotational speed (rad/s) for a given wall-thread. Your udf can't be hooked in the BC-menue of this wall but you may use e.g. DEFINE_ADJUST or EXECUTE_AT_END to update the rotation speed. In the GUI you will still see a constant (initial) value but it will change actually according to your specifications.
cheers
coglione is offline   Reply With Quote
Old   September 24, 2010, 04:24
Sounds good, thanks for the advice
Old   September 29, 2010, 11:43
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Another alternative is to use a scheme script that is run every time step. In this script you may use a TUI command to setup your rotating wall velocity.
dmoroian is offline   Reply With Quote
Old   October 19, 2010, 06:43
cheers
I tried using the macro, but I always get the ACCESS_VIOLATION error.
UDF paraboloid velocity inlet rosco FLUENT 10 June 2, 2017 08:01
Velocity of Fluid @ different positions of Particle in DPM using UDF pmghadge FLUENT 1 June 16, 2009 19:11
UDF Unsteady velocity profile Rashad FLUENT 0 February 27, 2008 14:57
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 12:20
