Sinusoidal motion udf
Old   May 23, 2010, 06:07
Default Sinusoidal motion udf
urmazda's Avatar
iman ashtiani
urmazda is on a distinguished road
Send a message via MSN to urmazda Send a message via Yahoo to urmazda Send a message via Skype™ to urmazda
hey guys
i have a problem but i am not so sure if it is due to my fluent or udf or other things
i want to find the pressure distribution around an airfoil (which has a sinusoidal motion) in a water tank. i have written the following code in C:
#include "udf.h"
#define om 0.62831853
#define pi 3.1415926
#define scale 0.1612
x(t)= 2c*cos(wt)
alpha(t)= pi/2 + pi/2*sin(wt)
DEFINE_CG_MOTION(vel, omega, time)
real b,u;
u = -2*scale*om*sin(om*time);
b = pi/2*om*cos(om*time);
vel[0] = u;
vel[1] = 0.0;
vel[2] = 0.0;
omega[0] = 0.0;
omega[1] = 0.0;
omega[2] = b;
but in fluent after building it in udf compiler, in loading time i am recived the following error;
Opening library "code"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
someone please help me
thank you in advance
urmazda is offline   Reply With Quote
Old   May 23, 2010, 09:47
DoHander is on a distinguished road
If you use Windows as I suspect modify the files view menu in order to let you see the extensions of the known file types.
Do
DoHander is offline   Reply With Quote
Old   May 23, 2010, 09:53
urmazda's Avatar
iman ashtiani
thank you, i am using windows and even i have had unmarked the "hide extension for known file type" previously.
and still the problem exists.
Old   May 31, 2010, 04:06
O.D.Y.'s Avatar
O.D.Y. is on a distinguished road
did fluent comile this udf without an error?
If you take a look at the manual, the DEFINE_CG_MOTION is defined the following way:
#define DEFINE_CG_MOTION(name, dt, vel, omega, time, dtime)
So I guess you forgot some variables. And you also didn't give a name, so how did you hook the udf in fluent?
O.D.Y. is offline   Reply With Quote
Old   May 31, 2010, 04:17
urmazda's Avatar
iman ashtiani
oops thank you but i think i pasted the wrong version of my c file here, in the main version i wrote as follow
DEFINE_CG_MOTION(pilo, dt, vel, omega, time, dtime)
indeed i have put name and other necessary variable!
but still i have the same problem!
Old   May 31, 2010, 05:07
O.D.Y.'s Avatar
Ok,
and do you have all your files in one directory and is there a directory named "code" after compiling?
It sounds as if some environment variables are not set properly.
Did you ever use another UDF before?
cheers
Old   July 30, 2010, 11:44
Default rotation around z axis
ahmad
almostafa67 is on a distinguished road
hi everybody...
i am trying to simulate peristaltic pump and for this i need to write an udf file to rotate on of edges about z axis,i will be thanfull if u could help me with this problem.
thank you in advance..
almostafa67 is offline   Reply With Quote
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 09:16
Grid motion with UDF fivos Fluent UDF and Scheme Programming 5 June 30, 2018 08:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
UDF for non sinusoidal or varying amplitude motion with respect to time lalit kumar FLUENT 1 November 13, 2010 16:58
UDF error CG Motion Alex FLUENT 0 March 22, 2006 17:40
