defining temperature profile with UDF
Old   August 2, 2010, 11:21
Default defining temperature profile with UDF
mohammad
mohammadkm is on a distinguished road
Dear all
I tried to define the temperature profile which is attached, with UDF.
Here is the UDF:
DEFINE_PROFILE(x_temperature,thread,index)
Domain *domain=Get_Domain(1);
real x[ND_ND]; /* this will hold the position vector */
real y,b;
face_t f;
begin_f_loop(f,thread) /* loops over all faces in the thread passed in the DEFINE macro argument */
F_CENTROID(x,f,thread);
y = x[1];
b=x[0];
F_PROFILE(f,thread,index) =295+(11734506.78*(pow((y/2),2)-(pow(y,4)/(8.1*0.00001))))-4.331683168+(15.8038854*b);
end_f_loop(f,thread)
I hook the UDF in the boundary condition and i can get the results without any problem. However the results are wrong.
Have i written the UDF correctly?
Please help me, i really stuck on this problem.
mohammadkm is offline   Reply With Quote
Old   August 2, 2010, 23:18
oldfreshman is on a distinguished road
how about change"F_PROFILE(f,thread,index) =295+(11734506.78*(pow((y/2),2)-(pow(y,4)/(8.1*0.00001))))-4.331683168+(15.8038854*b);
to this
"F_PROFILE(f,thread,index) =295.+(11734506.78*(pow((y/2.),2.)-(pow(y,4.)/(8.1*0.00001))))-4.331683168+(15.8038854*b);
oldfreshman is offline   Reply With Quote
Old   August 3, 2010, 02:28
mohammad
Thanks for your help.
I will try this. But what's the difference between them?
Old   August 3, 2010, 03:17
eg. 295, the type of variable is "int";
295., "real";
maybe this is ur problem.
Old   August 3, 2010, 03:24
mohammad
Thanks for your reply.
why shouldn't i put "." after 4.331683168.
For example
F_PROFILE(f,thread,index) =295.+(11734506.78*(pow((y/2.),2.)-(pow(y,4.)/(8.1*0.00001))))-4.331683168.+(15.8038854*b);
Old   August 3, 2010, 05:29
4.331683168.
oh, i don't think it a right way to discribe a real value either.
Old   August 3, 2010, 11:58
mohammad
Thanks again for your reply.
I checked that code too, but unfortunately the results were still the same and there was no difference between them.
I have a question about velocity profile.
Should i make this change in velocity profile too?
I defined velocity profile too.
UDF is:
# include "udf.h"
# include "math.h"
DEFINE_PROFILE(x_velocity,thread,index)
real y;
face_t f;
y = x[1];
F_PROFILE(f,thread,index) =2* 0.05391789*(1-((y/0.00225)*(y/0.00225))) ;
real y,b;
face_t f;
y = x[1];
b=x[0];
Thanks again
Old   June 24, 2013, 15:52
Default hi
UMICH
drek26 is on a distinguished road
How can I do the same problem but in 3d, thanks
to this
drek26 is offline   Reply With Quote
Old   July 2, 2013, 00:30
hamid
Hamid-Moezzi is on a distinguished road
hi all,
i am trying to write a udf for a linear temperature distribution along the wall as a temperature boundary condition. the wall is subjected to an end of 325 K and an end of 300 K temperature and a linear distribution should be peresent for the wall. the wall position from the origin -0.06 to +0.06 . i found a udf here but it seems that does not work because after interpreting and when i want to initialize an access violation error occurs. please please help me. this is the first time that i work with ansys fluent.
thank you.
#include "udf.h"
DEFINE_INIT(linear_temp,d)
cell_t c;
Thread *t;
real xc[ND_ND];
real m;
real Tt=325., Tb=300.;
real xb=0.06,xt=-0.06;
real dT=(Tt-Tb)/(xt-xb);
/* loop over all cell threads in the domain */
thread_loop_c(t,d)
/* loop over all cells */
begin_c_loop_all(c,t)
C_CENTROID(xc,c,t);
m=xc[0];
C_T(c,t)=Tb+(m-xb)*dT;
end_c_loop_all(c,t)
Hamid-Moezzi is offline   Reply With Quote
Old   July 2, 2013, 07:26
Yash Ganatra
yashganatra is on a distinguished road
You can't use C_T(c,t) = something ; FLUENT automatically computes cell temperature ; so that's the reason I guess access violation is coming ; go through FLUENT UDF MANUAL especially the DEFINE_PROFILE macro.
yashganatra is offline   Reply With Quote
Old   July 3, 2013, 00:09
hamid
thanks yashganatra,
I have change my udf to the the following code. is it correct for a wall boudary condition???
best regards
#include "udf.h"
DEFINE_PROFILE(linear_temp,thread,i)
real x[ND_ND];
real m;
real Tt=325.,Tb=300.;
face_t f;
m=x[0];
F_PROFILE(f,thread,i)=Tb+(m-xb)*dT;
Old   July 3, 2013, 00:15
Yash Ganatra
Just try it out and get back.
Yash
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 07:29
Define profile inlet_temperature in UDF mohammadkm Fluent UDF and Scheme Programming 19 December 24, 2013 22:42
UDF temp. profile BC Shashikant FLUENT 0 June 24, 2006 03:16
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 00:58
