ACCESS_VIOLATION error for tempreture jump boundary condition
Old   September 4, 2010, 08:22
Default ACCESS_VIOLATION error for tempreture jump boundary condition
iman mohammadi
eeman is on a distinguished road
hi all
I am trying to simulate heat transfer between parallel plates with tempreture jump boundary condition.
this is my udf:
#include "udf.h"
#define TMAC 1
#define meanfreepath 6.8e-8
#define underrlx 0.02
#define SPHR 1.4
#define THAC 1
#define prandtl 0.707
DEFINE_PROFILE(temprature_jump_top,f_thread,index)
face_t f;
cell_t c;
Thread *cell_thread;
real gamma;
real temp;
begin_f_loop(f,f_thread)
c=F_C0(f,f_thread);
cell_thread=THREAD_T0(f_thread);
gamma=(2*SPHR)/(SPHR+1);
temp=(-2+THAC)/(THAC)*gamma*meanfreepath/prandtl*(C_T_G(c,cell_thread)[1]);
temp=(1-underrlx)*F_T(f,f_thread)+(underrlx*temp);
F_PROFILE(f,f_thread,index)=temp;
end_f_loop(face,f_thread)
but when i want to use them as a boundary condition,or when i want to iterate it,this error will be appear:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
how can i solve this error?
I appreciate for any help
eeman is offline   Reply With Quote
Old   September 10, 2010, 06:54
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I think the problem is from the temperature gradient C_T_G. Read in the manual how to instruct fluent to keep the gradients. Check the udf manual, section 3.2.3, the paragraph Gradient (G) Vector Macros.
dmoroian is offline   Reply With Quote
Old   September 13, 2010, 02:45
Default hi
iman mohammadi
hi
thank you dmoroian
same as you i think the problem is from the temperature gradient C_T_G,but i dont know how can i solve it.
i read section 3.2.3, the paragraph Gradient (G) Vector Macros,but i couldnt find any thing that be useful for me
Old   September 13, 2010, 03:48
dmoroian's Avatar
Dragos
"In order to retain the gradient data (when you want to set up user-defined scalar transport equations, for example), you can prevent the solver from freeing up memory by issuing the text command solve/set/expert and then answering yes to the question Keep temporary solver memory from being freed?."
Old   September 15, 2010, 03:33
iman mohammadi
hi dmoroian,and thank you so much
i do it,but it's not useful.
do you have any other idea???
Old   September 15, 2010, 03:50
Default Debugger
dmoroian's Avatar
Dragos
Try to debug it!
One way is to insert
   Message("debug 0\n");
   Message("debug 1\n");
after each line of code and see where it crashes, or use a proper debugger like gdb.
See this link for a hint on how to do it: http://www.cfd-online.com/Wiki/Udf_debug
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
Help Urgent about changing boundary condition Anjum Naveed FLUENT 7 August 14, 2006 12:25
