How to set a cell or face property independent of BC
Old   July 2, 2010, 17:22
Question How to set a cell or face property independent of BC
TDi
Tim Diller
TDi is on a distinguished road
I am trying to simulate the deposition of layers of a powder under a heater. A layer is deposited at an initial temperature, then allowed to heat for a while. Then another layer is deposited at the initial temperature and allowed to heat, and so on. The boundary condition is mixed convection/radiation. I use a dynamic mesh UDF to add a layer of powder by deforming the geometry, but I need to set the temperature of the new layer.
I understand how to set the temperature using a DEFINE_PROFILE, but that would rely on having that specific property defined by the boundary condition, that is, I think I would have to have a constant temperature BC.
Is there a way to use something like
F_PROFILE(face_thread,boundary_thread,i)=temp
to set the cell temperature/density/thermal conductivity arbitrarily? How would I know which value of i to use, since that is supplied by the function hook?
Thanks in advance.
TDi is offline   Reply With Quote
Old   October 19, 2010, 19:59
Lightbulb
Brandon Hathaway
Hathaway is on a distinguished road
Send a message via ICQ to Hathaway
Hey, I had to do a similar thing as you, I was looking to update my BC every iteration somehow using DEFINE_ADJUST, which isn't passed a property_id like DEFINE_PROFILE is.
My solution involved a UDF file that contained both a DEFINE_PROFILE portion to set the initial BC and also identify the property_id that will later be used to change the BC later on, and a DEFINE_ADJUST macro that changed the BC for each iteration thereafter. I posted my implementation code in another thread, the link to which is below.
http://www.cfd-online.com/Forums/flu...tml#post279878
I tested this code and it looks like my boundary conditions were indeed changing as desired with each iteration. Hopefully this helps you out.
Hathaway is offline   Reply With Quote
cell temperature, properties, udf
Setting BC for each cell on face Geisel Fluent UDF and Scheme Programming 3 July 2, 2010 02:52
define boundary condition in just one cell face om1234 Fluent UDF and Scheme Programming 0 June 16, 2010 19:11
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Cell face values computation un unstructured grids Sergio Rossi Main CFD Forum 2 May 28, 2006 10:04
