Display boundary condition defined by UDFs
Old   February 17, 2011, 07:31
Smile Display boundary condition defined by UDFs
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Hi Everyone,
I have problem this Fluent software.
Because my boundary condition was defined by UDFs (parabolic profile velocity), I want to check accuracy it by interface graphic.
How can I display it in the interface graphic of Fluent?
Thanks in advance.
trantoan2008 is offline   Reply With Quote
Old   February 17, 2011, 15:58
Amir's Avatar
Amir
Amir is on a distinguished road
if your case is 2D, then your boundaries are lines, then from plot menu you can write data and check them.
else for 3D cases, create a line over your boundary and follow above.
Amir is offline   Reply With Quote
Old   February 17, 2011, 21:05
Smile
ThanhToan
Originally Posted by Amir View Post
Hi Amir,
Thanks for your help.
According to your instruction, I think that we only write data in the defined boundary condition when the solution is solving, isn't it?
But I want to check this condition before we run the solution.
Do you have other idea for this problem?
Thanks.
Old   February 18, 2011, 04:46
Amir's Avatar
Amir
it doesn't need that your problem converged! you set boundary condition, so after some iteration you can stop solving and check.
Old   February 18, 2011, 06:10
Smile
ThanhToan
Hi Amir,
That is good idea. I used this way to check accuracy boundary condition. But I faced new problem.
Firstly, I ran some iteration and stopped it. Then I checked by display contour plot at inlet boundary. In this case, I can see that the boundary condition distributed parabolic profile.
If I checked by display vector plot, the vector distribution is the same.
What is some thing wrong at there?
Old   February 18, 2011, 09:03
Amir's Avatar
Amir
that's right, probably because vectors belong to cell centers adjacent to boundary were solution didn't converge yet.
as I said before, the best way is to use plot menu, for 2d case plot velocity along boundary and in 3D case, make a line over that and follow above.
regards,
Old   February 18, 2011, 09:13
Default meshing in Gambit
Geth
arungeth is on a distinguished road
I want 2 know "How 2 define the ratio in gambit meshing?". Also, The First length,last length definations are....
arungeth is offline   Reply With Quote
Old   February 18, 2011, 12:12
Amir's Avatar
Amir
@ Geth:
the ratio is defined as the length of an element to adjacent previous.
Old   February 21, 2011, 06:24
Smile
ThanhToan
Hi Amir,
Thank your help.
Best regards.
Tran Toan
boundary conditions, udfs
Slip flow boundary condition on wall using UDFs mahdi haddad FLUENT 1 November 11, 2014 06:13
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
