Time dependence UDFs. Emergency
Old   February 27, 2011, 23:39
Exclamation Time dependence UDFs. Emergency
phanh
phanh is on a distinguished road
I am using UDFs for defining variation of velocity.vs. time function at inlet boundary condition. However, variation of velocity.vs.time function is not any function regulation (eg. sin(x) function), velocity varies time data which I get from *txt file (contain time and velocity, respectively). Anybody have any idea for this problem.
Thanks in advanced
phanh is offline   Reply With Quote
Old   February 28, 2011, 05:16
Amir's Avatar
Amir
Amir is on a distinguished road
you have two choices:
1) fit a specific curve to your data
2)use profile in FLUENT. (you can provide a text file that contains velocity descrete data VS. time)
Amir is offline   Reply With Quote
Old   February 28, 2011, 07:06
phanh
Hi Amir,
Acttually, I tried to fit data by using least square method and got time function which corresponds to variation of velocity. Also, I can read this data (veloctiy.vs.time) from *txt file into Fluent. However, I haven't yet understood how to get time data for time variable in C program. Now, I think I should use "CURRENT_TIME" variable to form time variable. Is that right? However, if I use this variable for time variable, when Fluent software running, how to get velocity correspond to time step?
Actually, I haven't yet enderstand unteady problem with UDFs.
Please help me.
Thanks
Old   February 28, 2011, 08:58
Amir's Avatar
Amir
Hi Phanh,
if you want to fit a curve to your data, you should use a UDF and define v=v(t), here you should obtain your proper curve equation before with other softwares and use that in UDF and you can use CURRENT_TIME variable for time.
when FLUENT running, CURRENNT_TIME is passed from FLUENT to UDF and from equation v=v(t), velocity is obtained in UDF.
regards,
Amir
Old   March 1, 2011, 18:31
Real Name :)
ComputerGuy is on a distinguished road
Phanh,
Post your velocity curve function and I'll post a UDF that will work.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   March 3, 2011, 03:48
Exclamation
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Originally Posted by Amir View Post
Hi Phanh,
regards,
Amir
Hi Amir,
If I want to use data from text file, what kind of variable should I define?
If we use time variable to define for time data, it means that there are no relation between time variable (time data) and time solution (which I think it's called by "CURRENT_TIME"). My understanding is right, isn't it?
I hope I will receive your responding as soon as possible.
Thanks in advanced.
Phanh.
trantoan2008 is offline   Reply With Quote
Old   March 3, 2011, 04:35
Amir's Avatar
Amir
Originally Posted by trantoan2008 View Post
Hi Amir,
Thanks in advanced.
Phanh.
if you want to use data from text file, it doesn't need to use any variable because it doesn't need to use any UDF! to obtain good result with this method you should prepare a text file with good resolution. it's better that reserve time step in both text file and FLUENT GUI.
for more information about this method you can also refer to:
(user guide FLUENT 6.3.26 -> 7.1.9 Defining Transient Boundary Conditions)
regards,
Amir
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Advection Time Anne CFX 15 March 1, 2018 16:53
UDFs and Time dependence.vs.Velocity trantoan2008 Fluent UDF and Scheme Programming 3 August 1, 2011 12:47
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
