March 9, 2011, 05:21 |
User-defined Time Step
Rep Power: 15 |
Hi all,
I would like to define a user-defined time step with the DELTAT UDF The UDF is defined this way: DELTAT(name, d) Domain *d: pointer to the domain over with the time stepping control fonction is to be applied. I need my time step to be depend on the angular velocity of my body Cg which is in rotation. I can't get the angular velocity with the DT_OMEGA_CG(dt) beacuse dt isn't declared in DELTAT so I don't know how to do. Does anyone would have an idea? Thanks! |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
