THREAD-ID in UDF
Old   March 16, 2011, 09:19
Default THREAD-ID in UDF
truffaldino's Avatar
truffaldino is on a distinguished road
I would be grateful if someone could help me to fix the problem.
I am using THREAD_ID(t) in if statement to set different visosities in different zones. But it does not work in " if (Thread_ID(t)==...) " statement in my UDF. Whe I run fluent with this UDF, it does not distingush between zones.
It is a very simple code, what could be wrong here?:
PHP Code:
#include "udf.h"
#define xtop -1.
#define xbot 0.
#define rho 1.225
#define nu 1.4607E-5
#define C3 357.9
#define idtop 11
#define idbot 10
DEFINE_TURBULENT_VISCOSITY(mu_tct)
real mu;
real nut;
real xi;
real r[ND_ND];
C_CENTROID(r,c,t);
    if(
THREAD_ID(t)==idtop)
            if(
r[0]>xtop)
nut=C_NUT(c,t);
xi=nut/nu;
xi=xi*xi*xi;
mu=rho*nut*xi/(xi+C3);
            else
mu=0;
    if(
THREAD_ID(t)==idbot)
            if(
r[0]>xbot)
nut=C_NUT(c,t);
xi=nut/nu;
xi=xi*xi*xi;
            else
mu=0;
return
mu;
truffaldino is offline   Reply With Quote
Old   March 16, 2011, 09:37
Amir's Avatar
Amir
Amir is on a distinguished road
for simple debugging, would you use a Message command to check whether it enters a if statement or not?
Amir is offline   Reply With Quote
Old   March 16, 2011, 09:57
Originally Posted by Amir View Post
I have checked it without message: I have just removed "if(THREAD_ID...) statements and everything works fine, as seen from postprocessing, except it chooses one viscousity function for all zones, so it does not enter "if(THREAD_ID...) statements
Old   March 16, 2011, 10:03
Old   March 16, 2011, 10:20
And there is another strange thing: when I put "Message" or "Error" statement, interpretor says:
function "CX_Message" not founs (pc=80)
or
function "CX_Primitive_Error" not found (pc=80)
Old   March 16, 2011, 10:52
Amir's Avatar
Amir
just a suggestion:
do not introduce idtop & idbot as:
#define idtop 11
#define idbot 10
try in define macro:
int idtop=11
int idbot=10
it may help !
Old   March 16, 2011, 11:13
just a suggestion:
#define idtop 11
#define idbot 10
int idtop=11
int idbot=10
it may help !
Thanks Amir,
I have already tried this: it does not help. I am wanderin, could it be an interpretor problem, since it does not recognize commands like "Message" and "Error"
Old   March 16, 2011, 12:38
Amir's Avatar
Amir
Thanks Amir,
you're right if you have such these problems with other UDFs with the same headers. is it the case?
Old   March 16, 2011, 14:29
Thanks Amir,
I have tried with other udf Message and Error macros do not work, so there is something wrong with an interpretter indeed.
Old   March 16, 2011, 17:39
I have solved the problem: it turns out that zone ID numbers must be taken as assigned by gambit (as in mesh file) and not as shown by fluent!
As for "Error" and "Message" makros they do not work, but can be replaced by "printf".
Old   March 17, 2011, 08:57
Amir's Avatar
Amir
really? I've used ID's that FLUENT shows for my UDFs before and they've worked.
would you please also checked that with other versions of FLUENT?
Old   April 3, 2012, 18:36
Nathan
natantyt is on a distinguished road
Hi
I've got the same problem with my UDF to define different diffusivities for different zones , did you solve this? I appreciate your suggestions. Did you define the zone ID from boundary box or cell zone box?
PHP Code:
#include "udf.h"
#define xtop -1.
#define xbot 0.
#define rho 1.225
#define C3 357.9
#define idtop 11
#define idbot 10
real mu;
real nut;
real xi;
real r[ND_ND];
C_CENTROID(r,c,t);
    if(
            if(
r[0]>xtop)
nut=C_NUT(c,t);
xi=nut/nu;
xi=xi*xi*xi;
            else
mu=0;
    if(
            if(
r[0]>xbot)
nut=C_NUT(c,t);
xi=nut/nu;
xi=xi*xi*xi;
            else
mu=0;
return
mu;
natantyt is offline   Reply With Quote
Old   April 4, 2012, 04:15
Hello Nathan,
Yes I have solved the problem but it was a long time ago: I remember that it turns out that zone ID numbers must be taken as assigned by gambit (as in mesh file) and not as shown by fluent! That is why my procedure was not working. So, in file I have presented above, it was necessary to change values of idtop and idbottom to those given by gambit in mesh file.
Truffaldino
Old   April 4, 2012, 04:19
Hello Amir,
I was not aware of your messge, sorry for late responce. Unfortunately I have no access to different versions of Fluent, so I cannot check it.
Truffaldino
Old   December 3, 2012, 07:51
Kanarya is on a distinguished road
Hi, I have problem to save mass flow rate at outlet
I did following udf but it seems UDMI doesnt work because it is always zero.
is there anyone who can help me?
thanks in advance!
here is my code:
#include "udf.h"
DEFINE_EXECUTE_AT_END(measure_mass_flow)
real mass_flow;
Domain *d=Get_Domain(1);
cell_t c;
face_t f;
Thread *mixture_thread = Lookup_Thread(d,4);
Thread **pt = THREAD_SUB_THREADS(mixture_thread);
Thread *tp = pt[0];
Thread *ts = pt[1];
mass_flow=0.;
mp_thread_loop_f(mixture_thread,d,pt)
if( THREAD_ID(mixture_thread) == 4 )
begin_f_loop(f,mixture_thread)
F_UDMI(f,mixture_thread,0)+= F_FLUX(f,tp);
end_f_loop(f,mixture_thread)
Kanarya is offline   Reply With Quote
Old   March 5, 2013, 13:36
W Z
zwbmimi is on a distinguished road
Hi, I also have this problem and fix it by using the ID provided by FLUENT, which can be found in BC panel.
zwbmimi is offline   Reply With Quote
Old   March 6, 2013, 04:31
hi Zwbmimi,
thanks for the answer!
I did it as well. But now i have problem to use it in parallel.
Can you use it in parallel..?
best regards
Old   March 6, 2013, 04:39
W Z
Yes, my UDF works in parallel.
Originally Posted by Kanarya View Post
hi Zwbmimi,
best regards
Old   March 6, 2013, 04:45
for what kind of application are you using it?
can you help me to make it parallel?
thanks in advance...
Old   March 6, 2013, 04:59
W Z
Hi, i include the thread id in source terms of my uds. Does your code work well in parallel without the tread id? I'm happy to help.
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
Parallelizing UDF Hattori Hanzo Fluent UDF and Scheme Programming 4 July 17, 2010 14:26
thread pointer comparison crash in Fluent UDF Miriam Main CFD Forum 0 August 31, 2008 16:40
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
UDF: Checking Thread Storage Greg Perkins FLUENT 0 March 10, 2000 20:35
