Thermal conductivity UDF
Old   February 25, 2012, 15:28
Default Thermal conductivity UDF
jack
jack.s is on a distinguished road
Hi friends...
i want to define thermal conductivity of fluid that varies with temperature and position. in other words i want to use this formula:
k= 3*T^2+6*y
that T is temperature and y is position in y-direction.
I wrote the following UDF and run the case but when i compared this result with constant thermal conductivity it has no effect in my results.
#include "udf.h"
DEFINE_PROPERTY(knew,c,t)
real ktc;
real y;
real temp = C_T(c,t);
ktc = (3. * pow (temp,2.)) + (6. *y);
return ktc;
can any body help me???
jack.s is offline   Reply With Quote
Old   February 26, 2012, 03:41
Sixkillers is on a distinguished road
Well in your code variable "y" isn't initialized, so I guess that is the problem. Here is an quick fix:
PHP Code:
real ktc;
real pos[ND_ND];
real y;
C_CENTROID(pos,c,t);
pos[1];
real temp C_T(c,t);
ktc = (3. pow (temp,2.)) + (6. y);
  return
ktc;
Sixkillers is offline   Reply With Quote
Old   February 26, 2012, 13:58
jack
PHP Code:
real ktc;
real pos[ND_ND];
real y;
pos[1];
real temp C_T(c,t);
  return
ktc;
Thanks a lot Sixkillers for your answer...
i use this UDF and my results changed!!! But my result is not satisfactory.
i have some other question:
i want to use this UDF in 2d modeling of pipe, and use this UDF to change thermal conductivity of fluid in each section of pipe from inlet to outlet with temperature and position of each point in every section.
can i use this UDF in axisemmetric model with y or i should replace y with r???
if yes, can i replace y with r in the previous UDF???
And if i want to use this formula :
k=3*T+ \partial(U)/\partial r
how can i change previous UDF ???
Old   February 28, 2012, 16:08
I think that you can use this code without any modification for an axisymmetric problem, if a symmetry axis is parallel with x axis. If it is parallel with y axis than you will have to change
PHP Code:
pos[1];
to
PHP Code:
pos[0];
To obtain a derivation of velocity according to spatial variable, you can use methods: C_U_G, C_V_G (take a look to this chapter).
Once again it depends, which spatial variable represents radius. Finally I would like to say, that I haven't test it and UDF manual isn't much speaking about axisymmetric problems in general. However, this is the way how I expect it should work
Old   February 29, 2012, 11:57
jack
PHP Code:
pos[1];
to
PHP Code:
pos[0];
Thank you very much...
I need one simple udf code for effective thermal conductivity of nanofluid mvf Fluent UDF and Scheme Programming 1 February 10, 2017 19:05
UDF for effective thermal conductivity Rashmi FLUENT 1 November 6, 2007 20:08
UDF for effective thermal conductivity Mona FLUENT 2 January 16, 2006 13:36
Can wemodify effective thermal conductivity by UDF FengYun FLUENT 2 October 27, 2005 05:28
Effective thermal conductivity UDF - C_K_EFF?? Craig FLUENT 4 February 11, 2004 14:02
