problem with udf
Old   September 8, 2011, 09:12
Default problem with udf
Harpreet
Harpreet is on a distinguished road
hello,
pls help
i am trying to vary the inlet velocity profile for which i have made a following udf
#include "udf.h"
DEFINE_PROFILE(variable_velocity,t,i)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y=x[1];
F_PROFILE(f,t,i)=7.36+0.368*y;
end_f_loop(f,t)
but the problem with it is that it is giving a constant velocity at the inlet that is 7.36. I think that probably it is not taking the coordinate into the equation.
pls help me. its urgent
Harpreet is offline   Reply With Quote
Old   September 8, 2011, 10:32
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Did you check your units? Also, is your inlet parallel to Y-axis or X?
Just suggestions though. I don't know about your case file.
pranab_jha is offline   Reply With Quote
Old   September 8, 2011, 12:59
Harpreet
yes i checked the unit, but don't know what effect will the inlet direction would make on the udf. although it is parallel to x axis
Old   September 8, 2011, 13:05
pranab_jha's Avatar
Pranab N Jha
Your profile varies with y and not x. Hence, the result will be a constant on the inlet when the inlet is aligned to the x-direction. Interchange the x and y coordinates.
Old   September 8, 2011, 13:27
Harpreet
thank u for ur reply
i tried with interchanging x & y, but still i am getting constant velocity
Old   September 8, 2011, 14:13
Harpreet
when i try to read the mesh with scaling in M units, it is showing the variation, but when i try to read the file in mm units its showing constant velocity. why it is show
Harpreet
when i try to read the mesh with scaling in M units, it is showing the variation, but when i try to read the file in mm units its showing constant velocity. why it is so. pls help me i am new to fluent
Old   September 9, 2011, 10:25
Mohammad
m2montazari is on a distinguished road
hi,
it is a dupplicated thread!
if you have a function 7.36+0.368*y and the variation of y is about 10 mm then the variation of velocity would be about 0.0037 and you may think a constant velocity is set in inlet. but if the variation of y is about 10 m then variation of velocity would be about 0.3 and you will see a linear velocity profile in inlet easily.
just think about that
yours,
mohammad
m2montazari is offline   Reply With Quote
Old   September 11, 2011, 00:51
Harpreet
thank you for ur answer. i am obliged
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
