Cannot use more than 1 UDF at the same time ?
Old   November 20, 2011, 08:57
Default Cannot use more than 1 UDF at the same time ?
Amarant is on a distinguished road
I write UDF, interpret it, hook it, everything works fine.
Than i interpret another UDF in the same case and 1st one disappear.
They can be same type or different type, it always does that. When I interpret an UDF, the one i had interpreted disappear.
Which is pretty problematic since i need UDF to set my boundary conditions and to initialize my flow field.
Is that a problem with FLUENT or am I doing something wrong?
Amarant is offline   Reply With Quote
Old   November 20, 2011, 09:03
Amir's Avatar
Amir
Amir is on a distinguished road
Store all of them in one file then interpret it.
Bests,
Amir
Amir is offline   Reply With Quote
Old   November 20, 2011, 09:09
Originally Posted by Amir View Post
Bests,
It is a must to do so or a solution to my problem?
I find it easier to create individual UDF, especially for boundary, interior, initialization and so on.
Thank you for your fast response.
Old   November 20, 2011, 09:14
Amir's Avatar
Amir
If you want to interpret your UDFs, you have to use this procedure but if you compile these UDFs, you could use different files. (I recommend compile mode, its faster and doesn't have any restriction, but you need extra compiler)
Bests,
Amir
Old   November 20, 2011, 09:20
Bests,
Didn't know that.
By compiler you mean that i cannot write them in .txt but I need complier such as QT?
Old   November 20, 2011, 09:31
Amir's Avatar
Amir
Didn't know that.
There isn't any different in developing UDFs in both methods in which you need ".c" extension; in interpret mode, you can use internal compiler of FLUENT which has some restrictions in definitions of few classes; indeed, it reduces speed of implementation; on the other hand, there aren't these restrictions with compile method which require visual c++ compiler linked with FLUENT. For this purpose, it's better refer here.
Bests,
Amir
Old   November 20, 2011, 09:37
Thank you very much, you helped me a lot !
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Availability of previous time level values in UDF ranga sudarsan FLUENT 0 September 1, 2008 09:17
