FLUENT received fatal signal (ACCESS_VIOLATION) |
December 22, 2011, 08:55 |
rose
I wrote a UDF for calculating surface tension and concentration. UDF is interpreted sucessfully, but after running for1 one iteration it is giving Access_violation error. best regards Last edited by rubis; January 11, 2012 at 04:11. |
December 29, 2011, 18:51 |
#2 | |
Real Name :)
Rubis,
Where are you defining the *tp pointer? I don't see anywhere in your code where you're defining it or passing it to the functions. If Rho and Yi are defined based upon it, and it's a null pointer, Fluent will quit with an access violation. Let me know if I'm missing something! Regards, ComputerGuy Quote:
December 31, 2011, 08:35 |
rose
hi,
thank you for your reply. can you give me more details.please it's a big priblem for me best regards |
January 2, 2012, 05:26 |
#4 | |
duri
January 2, 2012, 20:26 |
Real Name :)
Duri,
I agree this change would "fix" the problem with accessing a non-null thread pointer, but it looks like rubis is performing the calculation in a multiphase environment, and that *tp should be pointing to the second (or third?) phase cell thread (note the comment: *thread from phase identified by phase_2_ID*/). It also looks like there's a species mass fraction involved (C_YI)... Before we lead Rubis astray with things that will fix the error but not the problem, perhaps we should understand *what* Rubis is trying to calculate. Rubis: Please write down in words, not fluent UDF code, what you're trying to calculate, and what type of system it is. For example: I have a two-species, two-phase mixture. The calculation for surface tension is: Mass Fraction of Species 1 * Mixture Density of the Cell * 1000/456. Please write this as thoroughly as you can, and I'll be able to take what you write and turn it into Fluent code. ComputerGuy |
February 5, 2013, 01:15 |
hello computer guy
can you see why i get error "Fluent received fatal signal (access voilation). I am trying to run a dynamic mesh..of a body immersed in water.
April 22, 2014, 15:42 |
Initialize Error
mehdis
Rep Power: 12 |
hi all
when i initialize the below error occurs . , , FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f |
Free Surface Ship Flow | timfranke | OpenFOAM Running, Solving & CFD | 322 | March 3, 2021 09:04 |
FLUENT received fatal signal (ACCESS_VIOLATION) | CHAKER | FLUENT | 4 | December 11, 2015 03:20 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
fatal signal (ACCESS_VIOLATION) | manu | FLUENT | 0 | December 10, 2007 06:10 |
FLUENT received fatal signal (ACCESS_VIOLATION) | samy | FLUENT | 0 | November 10, 2007 13:09 |
