UDF for a time varying heat flux boundary condition |
November 21, 2013, 14:38 |
Mohamed
Rep Power: 15 |
I'm VERY new to Fluent and I'm attempting to write a UDF that will make the heat flux at a wall a function of time. I've never programmed in C before either so I'm having some trouble getting the correct sytax My function in Attach Files: Please help me to witre it I : Heat flux. A : area of the front surface. t : Time. T : Temperature. h : heat transfer coefficient. X : depth. Cp: specific heat \rho: density. Thank you. |
November 21, 2013, 16:44 |
Rep Power: 17 |
Please look into the UDF documentation there are some examples how to define a profile.
Macro to use is DEFINE_PROFILE(name,thread,nv) and then the function would be over F_PROFILE through the face_centroids in the face thread. |
November 21, 2013, 18:19 |
Mohamed
Rep Power: 15 |
Thank you, but can you give me an idea how write it please.
November 22, 2013, 13:38 |
François Grégoire
Rep Power: 17 |
here is an example, I guess you can just apply the profile on your boundary as a heat flux: http://www.cfd-online.com/Forums/flu...tml#post463127
November 27, 2013, 03:44 |
Rep Power: 26 |
August 5, 2018, 04:32 |
#6 | |
Rep Power: 8 |
I have written a udf for this but it is showing "segmentation fault". can you tell me where might be the problem ? Code:
#include "udf.h" DEFINE_PROFILE(fluxloss,thread,position) { real h; real T_ext; face_t f; begin_f_loop(f,thread) { h = 10; T_ext = 300; F_PROFILE(f,thread,position) =-10*(WALL_TEMP_INNER(f,thread)-T_ext); } end_f_loop(f,thread) } |
August 5, 2018, 22:06 |
Alexander
Rep Power: 34 |
try this code
#include "udf.h" DEFINE_PROFILE(fluxloss,thread,position) { real h; real T_ext; face_t f; Thread *t0=thread->t0; /* Do nothing if areas are not computed yet or not next to fluid. */ if (!Data_Valid_P() || !FLUID_THREAD_P(t0)) return; begin_f_loop(f,thread) { h = 10; T_ext = 300; F_PROFILE(f,thread,position) =-10*(WALL_TEMP_INNER(f,thread)-T_ext); } end_f_loop(f,thread) } |
August 7, 2018, 12:44 |
#8 | |
Rep Power: 8 |
August 7, 2018, 21:56 |
#9 |
Alexander
Rep Power: 34 |
DEFINE_PROFILE macro is using to define user-defined boundary condition. You may use it anywhere.
to set this profile as BC for UDS go to boundary conditions-> select face you are interested in -> select UDS tab -> select specified value -> select this profile instead of "constant" best regards |
August 8, 2018, 12:51 |
#10 | |
Rep Power: 8 |
it is working fine. but i have a doubt that the following expression is for heat flux, should i use specified flux instead of specified value? |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Constant Heat Flux Boundary Condition on Long Thin Pipe | CGramlich | SU2 | 3 | April 22, 2013 08:25 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
time varying boundary condition | cfd-student | CFX | 0 | April 15, 2008 08:31 |
UDF for time dependent heat flux | Rameshwar Ajja | FLUENT | 0 | February 16, 2006 00:26 |
