February 4, 2012, 05:52 |
UDF: how to identify interface in VOF model
Chemflame
I am doing unsteady state analysis of a 2-D droplet evaporation in an square box. I have considered 1 mm radius semi-spherical water droplet placed in a square box of 5x5 mm. The surrounding of the droplet is air. I am trying to give a constant evaporation rate as my source term at the interface of the water droplet and air (i.e. only the water on the interface will evaporate into the surrounding). I have tried to write a UDF but I am unable to understand how to find the interface at which I should apply Source term . Since this is VOF model so to find the interface I can find VOF in each cell and if it is 1, then I can say that it is water and if it comes less than 1 than I can say that it is mixture of water and air. As: #include "udf.h" DEFINE_SOURCE(mass_rate_source,c,t,dS,eqn) { Thread *t; cell_t c; real source; C_CENTROID (coord,c,t); if (C_VOF(c,c_t) ==1)&&(MISSING CONDITION) dS[eqn]=0.0; if (IT IS INTERFACE) source = 0.0001; else source=0; return source; } In the missing condiiton i need to find the VOF value of a vertically above cell and if it is less then 1 then it can be said that this is the interface. I am unable to understand how to write this portion . Any help would be much appreciated, Thanks!! Abhishek |
April 19, 2012, 02:11 |
#2 | |
Jacky
Rep Power: 14 |
begin_c_loop(c,t) { V[0] = C_U(c,t); V[1] = C_V(c,t); mag = NV_MAG(V); NV_D(xunit, = ,1,0,0); NV_D(yunit, = ,0,1,0); c_face_loop(c, t, n) { F_AREA(A, f,t); C_CENTROID(dr0, F_C0(f,t),t->t0); F_CENTROID(xf, f,t); NV_VV(dr0, =, xf,-,dr0); ds = NV_MAG(dr0); NV_VS(es,=,dr0,/,ds); XDOT = NV_DOT(es,xunit); YDOT = NV_DOT(es,yunit); if( YDOT <= 1.0 && YDOT > cos(15.0)) { top = n; } } /* end of c_face_loop */ ftop = C_FACE(c0,t,top); c1 = F_C1(ftop,t); /* This is ur condition */ if (C_VOF(c1,t_liquid) < 1.0) { message(" IT IS INTERFACE \n"); } } end_c_loop(c,t) HOPE this helps and is self-explanatory..... Regards, Bharat |
question about Heat transfer between two phases with VOF model | sooroo3 | FLUENT | 0 | February 15, 2011 03:24 |
UDF for linear PTT model implementation | dpitz | Fluent UDF and Scheme Programming | 1 | February 4, 2011 10:08 |
UDF to read data from a file for VOF model | Pablo | FLUENT | 0 | October 23, 2008 07:02 |
UDF for VOF interface moving with velocity V | Johann | FLUENT | 3 | June 10, 2006 04:42 |
UDF for VOF model | Kunal Ashar | FLUENT | 0 | September 8, 2004 13:13 |
