Obtain equation residuals in UDF
Like Tree2Likes
  • 1 Post By dmoroian
  • 1 Post By gearboy
Old   February 1, 2010, 14:26
Default Obtain equation residuals in UDF
Robert Bressan
robert.bressan is on a distinguished road
Hello!
I'm writing an UDF that makes an optimization.
So every iteration, it must check if there was convergence in the solver, so I can make the proper changes in my profiles.
Is there a way to return the current solver residuals?
Regards,
Robert
robert.bressan is offline   Reply With Quote
Old   February 9, 2010, 07:20
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Well not in udf but here is a scheme line that gives you the residuals for the specified or current iteration (see also Wiki Fluent Scheme):
(get-residual-norms-at 1001)
(solver-residuals)
wc34071209 likes this.
dmoroian is offline   Reply With Quote
Old   March 9, 2010, 03:06
gearboy is on a distinguished road
Originally Posted by robert.bressan View Post
Hello!
Regards,
Robert
This is an example to print the residuals on the console.
#include "udf.h"
DEFINE_ON_DEMAND(residual_list)
int nw;
real scaled_res;
Domain*domain=Get_Domain(1);
for(nw=0; nw<MAX_EQNS; ++nw)
if(strlen(DOMAIN_EQN_LABEL(domain,nw))>0)
if(0==DOMAIN_RES_SCALE(domain,nw)[nres-1])
DOMAIN_RES_SCALE(domain,nw)[nres-1]=1;
scaled_res=DOMAIN_RES(domain,nw)[nres-1]/DOMAIN_RES_SCALE(domain,nw)[nres-1];
Message("%s equation,residual=%g\n",DOMAIN_EQN_LABEL(domain,nw ),scaled_res);
gearboy is offline   Reply With Quote
Old   March 9, 2010, 03:34
Default What is nres?
dmoroian's Avatar
Dragos
Hi Ji,
Nice to see some undocumented macros at use, but what is 'nres' variable representing?
Old   March 9, 2010, 22:25
Originally Posted by dmoroian View Post
Hi Ji,
nres is the current number of residuals.
Old   April 1, 2012, 02:49
Exclamation
Small Mayi
ChenZhan is on a distinguished road
Dear my friends.Now, a similar problem I had come acrossed when edit a udf, while i copy this code and then try to compile as executable progame, an issue come out, the fluent tell me that subscript required array or poiter types. I think it maybe caused by the nres. Who can tell me how to treat it. I only want to obtain the residuals on the current time in my udf.
If anybody could have the same question and have solve it,please help me. Thank you.
ChenZhan is offline   Reply With Quote
Old   April 1, 2012, 03:02
Default ...post the error
dmoroian's Avatar
Dragos
Could you post the error you get not from your own memory, but from the computer screen?
Old   April 1, 2012, 03:11
Small Mayi
Ok
(system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0.0\sr c\makefile_nt.udf "libudf\win64\2ddp\makefile" ")
已复制 1 个文件。
(chdir "libudf")()
(chdir "win64\2ddp")()
# Generating ud_io1.h
test2.c
..\..\src\test2.c(11) : error C2109: 下标要求数组或指针类型
..\..\src\test2.c(12) : error C2109: 下标要求数组或指针类型
..\..\src\test2.c(13) : error C2109: 下标要求数组或指针类型
Done.
"下标要求数组或指针类型/chinese" means "subscript requried arrays or pointer types"
Thank you!!
Old   April 1, 2012, 10:08
dmoroian's Avatar
Dragos
Is it possible to post the code? Apparently you're trying to use as array something that's not.
Old   April 2, 2012, 09:47
Small Mayi
I am very appreciated for your help. In order to avoid to determine the convergence in my udf according to the residuals, I had choosen another
variable at the exit boundary ,and by monitoring its change to do the next work.
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
udf temperature/velocity profile-> equation problems roka1mtr FLUENT 2 August 25, 2009 04:44
UDF Addidtional Force to momentum equation sfawal FLUENT 10 July 15, 2009 09:29
UDF to switch on energy equation after X iteration mat w FLUENT 6 December 5, 2005 07:35
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
