April 20, 2012, 10:37 |
How to create 2 separate Surface Bodies?
Andrius
Rep Power: 14 |
I would like to know how I could draw up 2 discrete surface bodies without connecting into 1.
I am modelling a gas flow in a tube fitted with a bluff body entering atmosphere. I have two tube inlets and 2 outlets entering the atmosphere as shown: Many thanks |
April 22, 2012, 01:57 |
dengjiajia
Rep Power: 14 |
don't choose the connect option when you split the volume in gambit.
April 22, 2012, 02:45 |
#3 | |
Lucky
Rep Power: 66 |
This is all handled by whatever you used to generate the mesh. So how did you generate the mesh / model? |
April 22, 2012, 14:34 |
Andrius
Rep Power: 14 |
What do you mean?
I have drawn the geometry, and then selected the whole surface body and applied a triangular mesh. I would like to have the two parts connected but not as one piece... |
April 22, 2012, 14:51 |
Lucky
Rep Power: 66 |
You cannot build geometry/meshes in Fluent. So my question is, what did you use to make the mesh and build the geometry? In other words, your inquiry is not appropriate for the Fluent section as it does not pertain to Fluent at all.
April 22, 2012, 14:53 |
Andrius
Rep Power: 14 |
Oh, I have used DesignModeler to draw the geometry. I then used Ansys work bench Meshing to generate the mesh. The problem I have in Fluent that it reads it as one piece...
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 18:48 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
