Periodic BC help
Old   May 3, 2012, 06:08
Question HELP !!! Please !!! Periodic BC
felicemastronzo's Avatar
Felice
felicemastronzo is on a distinguished road
Hi all,
I try to obtain the same results like in the following pdf (see fig 7)
http://paginas.fe.up.pt/clme/IRF2009...PERS/P0222.pdf
I have create the geometry (like fig 7 in the pdf but only with one gap between two teeth) made by 1 single volume, 1 wall (the profile of the gear, 2 periodic bc on the sides , 1 symmetry plane (like in the pdf I have modeled only the half of the gear) and two p-outlet (one is planar ant the other has a curvature radius) ). I want to perform a steady simulation. In order to describe the rotation of the gear, I have imposed only a rotation to the walls (corresponding to the teeth profile). Is it correct? The results I get are strange and I want to know if I have made some settings mistake. Should I impose also a rotation to the volume? Should I change some periodic setting?
All kind of help is welcome!
Regards
F
felicemastronzo is offline   Reply With Quote
Old   May 3, 2012, 09:23
Felice
Nobody can help me?
F
Old   May 7, 2012, 02:28
delaneyluke is on a distinguished road
A moving (rotating) wall alone won't help, you need to define a rotating reference frame as well. Use the option of "frame motion" with Fluent.
P.S. The paper specifies that the equations are solved in a rotating reference frame.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   May 7, 2012, 05:55
Felice
so I have just to apply a rotating ref. frame or also some moving B.C.?
Thanks
F
Old   May 7, 2012, 06:12
Both
Regards
Luke
Old   May 7, 2012, 07:20
Felice
Thanks a lot!
If I have correctly understand I have to impose a rotation to the ref. frame and the same rotation to the gear boundaries (walls). The periodic boundaries, the symmetric boundary and the p-out boundaries, instead, are steady... correct?
But if the ref. rotates, the gear boundaries (that are moving) becomes steady (in the rotating ref.) and the other ones becomes moving boundaries. So in order to have the right results, I have, for example, to plot all the relative velocities instead the absolute ones, right?
Regards
F
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 08:00
[ICEM] how to define periodic for free type face in hexa meshing mingersai ANSYS Meshing & Geometry 0 February 5, 2012 01:55
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 17:46
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
