May 11, 2012, 15:01 |
HELP!! parse error in UDF
Fer Villa
I'm using the VOF model in 3D, with water (ID=2) as primary phase and air (ID=3) as secondary phase. I made a UDF for initializing volume fraction of phase air with the Taylor bubble form (a cylinder with a half sphere at the top).
#include "udf.h" #define Xc 0.0 #define Yc 0.0 #define Zc 0.045 #define r 0.0085 DEFINE_INIT(gas_fraction_axis,mixture_domain) { int phase_domain_index; cell_t c; Thread *ct; Domain *sd; real X[ND_ND]; sub_domain_loop(sd,mixture_domain,phase_domain_ind ex) { if (DOMAIN_ID(sd) == 3) thread_loop_c(ct,sd) { begin_c_loop_all (c,ct) { C_CENTROID(X,c,ct); line 25 if (X[2]<=Zc && sqrt(ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2)))<r) C_VOF(c,ct)=1.; line 27 else if (X[2]<=Zc && sqrt(ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2),pow(X[2]-Zc,2)))>r) C_VOF(c,ct)=1.; line 29 else C_VOF(c,ct)=0.0; } end_c_loop_all (c,ct) } } } When i interpret my UDF file, it says parse error in line 25, line 27 and line 29. This UDF is similar to that appear in UDF manual FLUENT 12 page 333, but I don't know why it fails. Someone knows the problem? Thank you Last edited by fevi84; May 11, 2012 at 16:39. |
May 12, 2012, 10:02 |
You can not have
sqrt(ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2)))<r) sqrt and , in it. If you want to have it as power, then remove this sqrt and use pow. |
May 14, 2012, 12:48 |
Fer Villa
Thank you mali28.
I found the error. The error is ND_SUM(pow(X[0]-Xc,2),pow(X[1]-Yc,2))), due to ND_SUM is setting for 3D. In the below expression lack the z component. ND_SUM(x, y, z) 2D: x + y; 3D: x + y + z; The correct expression in the line 25 is: sqrt((pow(X[0]-Xc,2) + pow(X[1]-Yc,2)))<r doing that, it works |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
parse error in transient udf | spring | FLUENT | 1 | July 6, 2010 06:26 |
UDF parse error at profile function line | Wiggy | Fluent UDF and Scheme Programming | 1 | July 27, 2009 15:59 |
PARSE ERROR Message when interpreting UDF in FLUENT | dhimans | FLUENT | 0 | May 24, 2009 11:40 |
UDF parse error on line 1 ..... (Unusual) | Amit Maha | FLUENT | 4 | June 30, 2006 12:15 |
