November 26, 2018, 00:25 |
Boussinsque or incompressible ideal gas
Nived Sankar
Rep Power: 8 |
Iam modelling a 2d natural convection of cylinder. The cylinder is 1 inch in diameter. The heat flux given to cylinder is 800w/m2. Fluid is air.
Should i choose boussinsque or incompressible ideal gas for density?? Please help.... |
November 26, 2018, 00:49 |
Lucky
Rep Power: 66 |
Incompressible ideal gas is slightly more general than Bousinesq because it allows the density to vary with temperature. With Boussinesq, you are only adding a body force term which is proportional to temperature difference (i.e. the gravity term only, the density is constant). For small heat fluxes (whatever small is), both should give very similar results.
November 26, 2018, 01:05 |
Nived Sankar
Rep Power: 8 |
Iam taking fluid domain as rectangle. Bottom part taken as inlet and top as outlet. The side walls are adiabatic walls. For natural convection, inlet and outlet , pressure boundary conditions are used. For natural convection, how much velocity should i get at inlet??
November 26, 2018, 01:54 |
Lucky
Rep Power: 66 |
If you don't know the velocity, why are you trying to impose a velocity boundary condition?
December 1, 2018, 00:47 |
Nived Sankar
Rep Power: 8 |
Which model should i choose for a rotating cylinder in natural convection?? My grashofs number is in the range of 10^6
Please help |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Difference between Ideal gas and Incompressible Ideal gas law | kr660170 | FLUENT | 2 | July 3, 2018 02:13 |
Convergence issues with Mixture model, when gas treatment changed to ideal gas | DVS | Fluent Multiphase | 1 | September 23, 2013 11:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
ideal gas law in turbulent flow | Achim | Siemens | 0 | March 26, 2003 14:38 |
