Atomization Simulation
Old   September 24, 2012, 12:35
Default Atomization Simulation
Paul
pmbov is on a distinguished road
Hi All,
I am working on my graduate thesis and I would like some help please. I am running a simulation of a pressure swirl atomizer, the fluid is water and existing into air (also, running into high ambient temperature). Than I will be running the same analysis exiting into superheated steam (which is moving in the direction with the spray). My question is:
1. I know I should use a Discrete Phase model analysis, but, should I couple the analysis with another model?
2. Are there any examples (or a tutorials) on how to run this simulation in ANSYS?
Any help would be greatly appreciated.
Thank you all for your attention.
-Paul
pmbov is offline   Reply With Quote
Old   September 25, 2012, 10:59
shoeb khan
shk12345 is on a distinguished road
Originally Posted by pmbov View Post
Hi All,
DPM is a quite resionable model to be used in that situation that can be used as the model that u r using is good enough for this purpose.
you will not be able to find any examples of this simulation anywhere . so don't try to search them . Use hit and trial to learn and the use it.
-Paul
Also VOF and Eulerian models can be used in this case.
Hope that helps
shk12345 is offline   Reply With Quote
Old   September 26, 2012, 13:38
Paul
Does it make since to couple a DPM with a Multiphase model in the analysis where the spray is discharging into moving steam flow?
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
