June 7, 2004, 14:09 |
swirl flow
hi friends
how to model a swirl flow.....in a 2D combustor with velocity inlet and pressure outlet as a boundary conditions.I tried by selecting define---models---solvers----axisymmetric swirl flow. Is this is the correct way. if this is the correct way then how to calculate 1.Axial component of flow direction 2.Radial component of flow direction. I know only inlet air velocity and swirl number for example (velocity 1m/sec and swirl number 0.3). Ofcourse mass flow also I know. If there is any literature plz do help me Thanks in advance regards rvndr |
June 8, 2004, 03:56 |
Re: swirl flow
ihave some experimental results of swirl flow when modeled same in fluyent i am not getting required pressure drop. can you help me.
June 8, 2004, 05:27 |
Re: swirl flow
What discretization scheme and turbulence model are you using?
June 8, 2004, 12:35 |
Re: swirl flow
Hello Amit, I am also modeling gas turbine combustor with all of the flow features using fluent. May be we can share the information/results for better undrestanding of flow physics ..
Regards, Gaurav |
June 9, 2004, 02:13 |
Re: swirl flow
Dear Tom If you can allow me to attach me on your mail the brief details i can describe the same. thank you
August 4, 2009, 02:41 |
swirl flow.....
siva kumar
Rep Power: 16 |
Hi frns,,,,
Am also doing seirl flow in combustor model but i sonno how to calculate the components like axial,,circumferential i.e,,,,,swirl velocity,,,,,,i know my swirl no and velocity,,,,,if u know any calculation theory regarding this plzzz help me? my email id :shshiva17@gmail.com |
December 2, 2010, 03:09 |
I also have this problem
Saeed
hi friends
how to model a swirl flow.....in a 2D combustor with velocity inlet and pressure outlet as a boundary conditions.I tried by selecting define---models---solvers----axisymmetric swirl flow. Is this is the correct way. if this is the correct way then how to calculate 1.Axial component of flow direction 2.Radial component of flow direction. I know only inlet air velocity and swirl number for example (velocity 1m/sec and swirl number 0.3). Ofcourse mass flow also I know. If there is any literature plz do help me Thanks in advance |
December 3, 2010, 03:10 |
need help for k-e turbulence model,RNG
naresh
Rep Power: 15 |
PROPELLER-rotation clockwise.
domain:::::inlet was considered of distance of 3D from mid of chord of root section and outlet is considerd upto a dist of 4D from axis of hub. at J=O.45, N=783.6RPM, Va = 8.23m/s It is steady flow, turbulent model- RNG K-E. domain with dia 4d, length 7d, d=1.4m. material- water_liquid. |
May 28, 2012, 05:45 |
#9 | |
Rep Power: 14 |
my email ID is: rangwala.juzer@gmail.com |
May 28, 2012, 05:46 |
#10 | |
Rep Power: 14 |
May 30, 2012, 02:53 |
#11 |
James Willie
Rep Power: 17 |
Hi, do you have a copy of this book: gas turbine combustion by arthur lefebvre? I think it would be helpful to you.
swirl flow in FolwWork Simulation | linsir0825 | FloEFD, FloWorks & FloTHERM | 1 | June 7, 2011 05:02 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 10:54 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
HElP!!!! Swirl flow in tube | khairy | FLUENT | 0 | August 4, 2005 18:04 |
