Nanofluid Modeling at Microchannel Heat-Sink
Old   June 4, 2012, 05:46
Question Nanofluid Modeling at Microchannel Heat-Sink
Behzad
mech-engineer is on a distinguished road
Hi every all
Pls tell me is it possible to simulate nanofluid as Eulerian two-phase flow in microchannel in FLUENT?
I'm working with CFX to model above mentioned problem,but I can't gain correct solution specially for heat transfer equations of two phases,namely dispersed solids and continuous fluid.Do you have appropriate way to overcome this problem in software or I should choice another way?
mech-engineer is offline   Reply With Quote
Old   June 4, 2012, 08:07
Amir's Avatar
Amir
Amir is on a distinguished road
Dear Behzad,
Why didn't you use UDS (scalar transport) instead of multi-phase modelling?!
Bests,
Amir
Amir is offline   Reply With Quote
Old   June 4, 2012, 11:26
Question
Behzad
Hi Amir
I had never used this option (UDS).Pls explain more about it and tell me how it can be applied to my modeling?Can I obtain a good solution via UDS for nanofluid flow in microchannel?Also tell me,did you never simulate nanoscale flow in FLUENT to assure me about obtaining a reasonable solution in this software?
Old   June 4, 2012, 11:47
Amir's Avatar
Amir
UDS is an auxiliary scalar equation used to evaluate secondary phase concentration:
\frac{\partial}{\partial t} \rho C + \nabla . (\rho U C) = \nabla . (\rho D \nabla C) + sources
It's common to use this capability in nano fluid simulations.
Off course you can. It can properly model convection and diffusion mechanism and you'll probably need additional UDFs for correcting other properties.
Bests,
Amir
Old   June 4, 2012, 11:57
Question
Behzad
You said,probably need to correct other properties.Which properties are your meaning?Can I use conservation equations at default form for nanofluid or it is necessary to correct them?How I can apply Cunningham slip correction factor on the drag coefficient to ensure no-slip condition for flow around a sphere nanoparticle?
Old   June 4, 2012, 12:10
Amir's Avatar
Amir
Dear Behzad,
This equation has a conservative form and we are talking about Eulerian approach not lagrangian so we don't have Cunningham factor explicitly; i.e, we implicitly model nano particles, we model their effects; otherwise if you insist on using Lagrangian approach (DPM models) you'll face few bugs in modelling brownian motion. Regarding additional UDFs; they're needed to correct fluid viscosity and density and so on ....
Bests,
Amir
Old   June 12, 2014, 03:32
shenyan
shenyan is on a distinguished road
Hi every all
hello sir
yes you can use fluent and upper version of it(ansys) to model a two-phase flow easily.you can fallow this manner
Define>>models>>multiphase>> then you can choose your model,there are 3models (mixture,wet vapor(i think) & eulerian).
shenyan is offline   Reply With Quote
[GAMBIT] Modelling CPU radial heat sink fan r.sirait ANSYS Meshing & Geometry 3 June 4, 2012 01:57
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Modeling Heat Generated by Gas Flame (CFDesign) Ross Fotheringham Autodesk Simulation CFD 2 October 30, 2007 11:25
Model of heating of computer heat sink with pcm anthro Main CFD Forum 6 June 5, 2007 22:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
