Contra rotating rotor simulation using mixing plane method
Old   June 18, 2012, 16:04
Default Contra rotating rotor simulation using mixing plane method
venkatesh
venkat_aero2007 is on a distinguished road
Hi everyone,
I am trying to simulate flow around Contra rotating rotor using mixing plane method. I have some doubt in defining boundary condition on rotor blade.
I defined Front rotor and Second rotor as Stationary wall.
Front rotor is rotating in Counter clock wise direction (according to Right hand thumb rule). So i define the fluid in the Front rotor region as Moving reference frame which rotates about X- axis (1 0 0) at -1800 rpm (negative sign for Counter clockwise direction), Relative to Cell zone:- absolute.
The second rotor rotates in opposite to that of Firs rotor about X-axis (1 0 0) at 1800 rpm (Positive sign for clockwise direction). relative to cell zone: Opposite to front rotor Fluid
When I check the Relative velocity vector, The Direction of the relative vector for the front rotor is along Counter Clockwise direction which is wrong ( it should be in clock wise direction because of the fact that the blade rotates in counter clock wise direction) but the relative velocity vector for the second rotor looks perfect.
Please can someone help me to define the proper boundary condition.
thanks in advance for your information,
Venkatesh
venkat_aero2007 is offline   Reply With Quote
Old   August 29, 2012, 05:36
Far
Sijal
Originally Posted by venkat_aero2007 View Post
Hi everyone,
Because you are looking at velocity vectors in second rotor reference frame. Choose the correct domain and velocity vectors will look fine.
Contra rotating rotor csmistry CFX 7 November 15, 2010 04:09
MFR and mixing plane boundary . Mica Main CFD Forum 0 January 26, 2007 09:40
Frozen rotor and mixing plane - difference? sam CFX 2 November 27, 2006 14:14
mixing plane sam Main CFD Forum 0 September 19, 2006 10:59
mixing plane in CFX5.5.1 joseph CFX 1 April 17, 2002 18:09
