TUI for material properties
Like Tree2Likes
  • 1 Post By Marion
  • 1 Post By Marion
Old   July 26, 2012, 14:21
Default TUI for material properties
Negin Nazarian
nenazarian is on a distinguished road
Hi
I want to define new material properties that are not in fluent database using TUI but Im just wondering in a loop and cant properly do that.
Can someone plz help me ?
Right now I need to define 3 new material and in my further steps of simulation I need to change some of their properties. So maybe I should save a file and edit that and have a TUI command to read that saved file.
Anyway Im not able to do any of these options.
Appreciate your help.
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   July 27, 2012, 04:27
Marion
Marion is on a distinguished road
Hi Negin,
To create a new material (liquid replaces air) I use this - I only change density and viscosity:
define materials change-create
air
liquid
yes
750
n
n
yes
0.02
n
n
n
yes
SSG_NJ likes this.
Marion is offline   Reply With Quote
Old   July 30, 2012, 20:10
Negin Nazarian
Hi
Thank you for your response.
The only problem is that this only works if the material-name is in the fluent data-base (such as air)
however, Im defining some material properties using user-defined database option.
Any suggestion on that?
Cheers
Negin
Old   July 31, 2012, 02:27
Marion
I think you didn't understand the commands:
I replace "air" (which is the default in Fluent) by a material called "liquid", which is not in the Fluent database, and for this new material I define a new viscosity and desity.
Marion.
SSG_NJ likes this.
Old   July 31, 2012, 15:28
Negin Nazarian
Oh I just figured it out.
Thank you so much for your help.
Cheers
Neg
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 17:26
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
