Fluent exceeding Solution Limits on faces
Old   July 9, 2012, 20:44
Default Fluent exceeding Solution Limits on faces
bawfuls is on a distinguished road
I am using Fluent with a compiled UDF to provide some boundary conditions, specifically a wall heat flux (but the UDF should be irrelevant to this particular issue). I have set the minimum and maximum temperatures in Fluent to 200 K and 2200 K, respectively via the Solution Limits box under Solution Controls. Despite this, when I use the UDF command F_T(face,f_thread) to query the temperature on a boundary face, Fluent often returns a value well outside these temperature limits (including very negative values). Do the Solution Limits specified under Solution Controls not apply to faces? How can I force Fluent to limit ALL temperatures (including faces) to these limits?
bawfuls is offline   Reply With Quote
Old   July 10, 2012, 00:20
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Maybe you could use a bounded scheme (like first order upwind) for the computation of the Energy equation.
flotus1 is offline   Reply With Quote
Old   July 10, 2012, 15:49
I am already using first order upwind for the energy equation in this case, so that doesn't seem to be the issue.
Old   July 10, 2012, 16:34
flotus1's Avatar
Alex
You are right, with a first order upwind scheme, over- and undershoots should not appear, especially when the range of the variable is set as a limit for the solver.
I'd be interested in a solution to this problem too.
My current analysis features a melting process in which the liquidus temperature is exceeded before the cell is fully melted.
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Initial solution fluent fevi84 Fluent UDF and Scheme Programming 1 June 23, 2012 12:10
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
